Chris NottEM Tuning
Results 1 to 7 of 7
    May 2012
    27
    MAF unplugged, runs fine. New MAF, worse gain?
    I have been having some issues with my car, i fitted new coils, plugs, full coil loom, injector seats, inlet gaskets. Still no better, i had done some logs with VCDS and MAF readings seemed all good. I then read on a post that the MAF logs dont tell the full story. The MAF that was on the car was a genuine recon approx 2 years ago so sort of dismissed it. One day i just thought id unplug the MAF see what happens, car drove much smoother. Got on the net straight away and got another genuine MAF ordered. Fitted it and staight away i realised my old MAF was probs OK. Ive unplugged the new MAF and its running smoother again??? Could this be because there ia unmetered air getting in? And with it unplugged its going of the base MAF tables?
    16Klappe's Avatar
    Certified S3 Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    4,899
    Visit 16Klappe's Instagram Channel
    Maybe a connector issue, more than likely your new maf is also faulty.
    I have honestly had more faulty new MAF's than working ones.
    I quite often say I'm going to do things.
    Then never do them.
    May 2012
    27
    Quote Originally Posted by 16Klappe View Post
    Yes i will try and have a look at the connector/wiring to the MAF, Surely 2 out of 2 genuine MAFs arent faulty? when i had the MAF plugged in i did some logs and the MAF readings looked fine? would this not show up a connector issue? Are there any other sensors that are linked to the MAF? That would also in effect be unplugged when i unplug my MAF?
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,899
    I had four in a row. All faulty.
    Where did you get the MAF? Not Euro or GSF I hope?
    Then never do them.
    May 2012
    27
    No way! Thats shocking! Got both mine from ECP :-( They are bosch recon. Isnt that what you get from the stealers?
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,899
    Nope.
    Euro are known for selling duff MAF's, ask anyone who knows their stuff on VAG and they will say the same.
    Buy a genuine from Audi or a known good used on eBay and take a chance.
    Then never do them.
    May 2012
    27
    Nope.
    Will speak to a mate and try his see how she drives. I just thought if it was a genuine bosch refurb it would be as good as a dealer maf. You would think they would get tested before leaving the factory? Poor service from Bosch! I believe the car will be running in open loop with maf disconnected? What other sensors will run open loop with the maf??
  1. new maf etc still limping!
    By Evstdi in forum Diesel forum
    Last Post: 30th January 2006, 16:32
  2. new MAF
    By Khufu in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th September 2005, 13:45
  3. Running without a MAF
    By JamesA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th July 2005, 19:28
  4. MAF / Airflow / Running problems
    By SimonA4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th July 2004, 17:45
  5. Anyone here bought a new MAF for A3 turbo?
    By Stuart_A3_Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th January 2004, 22:16
