AH FabricationsChris Nott
Results 1 to 7 of 7
    Feb 2009
    31
    16396 fault code help
    Took my car to the stealers today for an MOT and they failed it on exhaust omissions.
    They said that they had done some diagnostics of the lamda probes and that had come back fine, which suggested that it was the cat at fault. They then said that for a further £160 they would diagnose whether the CAT was indeed at fault.
    Didn't bother with that and took the car home plugged it into VAG COM and there is the following fault:
    16396 - Bank 1 : Camshaft A (Intake): Advance Setpoint not Reached (Over-Retarded)
    P0012 - 35 - 10 - - - Intermittent
    Been doing a lot of searching on here and other forums to see what the problem is, and from reading other posts it seems like it is either vvt adjuster or oil pressure related.
    All cars that had this fault seem to have bad idling/running issues which my car doesn't have which is confusing.
    I take it this would also give me bad omissions?
    Any help or clarity on this would be greatly appreciated. Cheers
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,460
    Telling us what car you have would help (model/year/engine code...)
    Assuming you have a facelift 8L of some description (this code is VVT related)... this is indeed related to a faulty VVT tensioner and/or oil pressure...
    On cold start do you get any rattling noises? faulty VVT makes a brrrraaatt!... noise...
    <tuffty/>
    Feb 2009
    31
    Yeah sorry it's an 02 S3 8l BAM.
    Idling its seems fine, but I do get a strange rattle when driving slowly at low revs. Last year Audi couldn't suss out where the noise was coming from but looks like the tensioner. (Only done 1100 miles this year)
    So hopefully a new tensioner and oil flush and change will sort it out.
    This will sort the omission issue aswell I hope, was looking at over a grand to do the whole exhaust a few hours ago!
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,632
    16396/P0012/000018 - Bank 1: Camshaft A (Intake): Advance Setpoint not Reached (Over-Retarded)
    Possible Symptoms
    Erratic Idle
    Possible Causes
    Intake Camshaft Adjuster tight/stuck
    Intake Camshaft Adjuster faulty
    Possible Solutions
    Check Intake Camshaft Adjuster
    Use Output Test, Meas. Value Blocks (MVB) & Basic Setting
    May 2012
    RETFORD, NOTTS
    1,748
    Wow Audi were going to charge how much to scan it?!
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Feb 2009
    31
    Quote Originally Posted by @udi A3 View Post
    Na they said they would inspect the cat for £160. No thanks!!
    chris99's Avatar
    s3 driver
    Dec 2010
    54
    hi marty, did you sort it out?
    i'm having the same error and don't have any ideea where to start from..
    Audi S3 8L
    OZ Superleggera | Bilstein B14 | BMC CDA | K04 | FMIC | SACHS Race Engineering | Brembo Sport GT | EBC Redstuff
    Live to drive, drive to live
  1. Fault codes help
    By Andy_S3 in forum VCDS (formerly VAG-COM) forum
    Last Post: 3rd December 2008, 20:27
  2. 2.8 V6 fault codes help
    By stapo69 in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th June 2008, 18:00
  3. fault code help
    By Audi_nut in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th May 2008, 20:33
  4. fault code help
    By vw754 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th June 2007, 23:43
