AH FabricationsSky Insurance
Thread: Turbo
    Mar 2013
    Bridgwater, Somerset
    45
    Turbo
    A few m8's now have had turbo failures, and I was wondering if this is normal to the 1.9 tdi at a certain point in their life.
    Is it a lack of lubricant or some other mechanical fault.
    One friend chipped his car out twice from 140 to 170 and was told that because he had not increased the psi in the turbo it would likely fail again before long.
    Not sure on how true that would be.
    On the other hand I know people who have never had a problem with their turbo's including the daughter's 1.9 2002 tdi sport which has done 225,000 now.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,453
    Define turbo failure?... its common for the VNT to choke up causing overboosting...
    Derv turbos run high boost as standard...
    <tuffty/>
    TDIQ's Avatar
    8L > 8P > 8V
    Jul 2009
    777
    I wouldn't see the turbo as a consumable type item like a clutch or brake pads. I wouldn't say that TDI turbos are bound to fail at some point if they're cared for with regular oil changes and most importantly warming up and cooling down (though the majority probably don't bother)
    My 1.9TDI is about to hit 200k on what I believe is the original turbo, clutch and flywheel and pulls very strongly throughout all the gears.
    '02 A3 TDI quattro sport
    8L IS DE BEST
  1. Logging turbo boost with VAG-COM
    By Ram in forum VCDS (formerly VAG-COM) forum
    Last Post: 26th January 2009, 22:23
  2. Turbo noise
    By AndybS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th July 2003, 21:10
  3. turbo hose set
    By waynehiscock in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th May 2003, 23:24
  4. Hot Turbo Pic
    By mramage in forum Other Brands & Models
    Last Post: 23rd March 2003, 23:36
  5. CLIFFORD Car alarm (Turbo Timer thing)
    By A4Steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th January 2003, 13:03
