EM TuningSky Insurance
Page 1 of 4 1234 LastLast
Results 1 to 40 of 153
Like Tree29Likes
Thread: Getting back on the road
    Dec 2011
    630
    Well the car is in my mates garage waiting on a new engine.
    Still looking good
    im going to be buying Stacey's bam engine.Any tips on putting a bam engine in replace of apy engine would be greatly appreciated .
    So hopefully the car will be on the road again sooner rather than later :-)
    Sandra likes this.
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,463
    Thats great news Robert, once you get the new engine from Stacey things will move along quickly. The car lives on. x
    Dec 2011
    630
    Quote Originally Posted by Sandra View Post
    Yeah it lives on :-)
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,098
    A few pics of the engine
    These are since both block and deck being machined, have since given the block a lick of black gloss engine enamel
    Couple of other random ones whilst stripping it down
    Will put it all back together next weekend then will wing its way up to you
    Power & Torque 335bhp 285ftlb
    0-60 4.64 1/4 mile 13.02
    My GTX3071r Build Thread
    http://www.audi-sport.net/vb/a3-s3-f...ld-thread.html
    Dec 2011
    630
    Quote Originally Posted by StaceyS3 View Post
    Thanks man,yeah just when ever your ready as I'm away for 17 days come Monday so just at your leisure mate
    lovemelongtime's Avatar
    Jun 2012
    Horsham
    335
    Just wondering what wheels do you have your car?
    Dec 2011
    630
    Quote Originally Posted by lovemelongtime View Post
    oz superleggera 18"
    Dec 2011
    630
    Dose anyone know what else I will need to get to get the bam engine running in the car as it was apy befor and it had sai and no vvt but bam doesn't have sai but has vvt
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    Thought I had already covered this dude....
    Swap tensioner, remove SAI, use APY sensors etc... done
    Use new gaskets (genuine ones) for everything you remove so coolant and oil, exhaust, tensioner etc... use your cam cover (get a new gasket for this too)
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    ...is the engine built? new cam belt, water pump, cam belt tensioners?
    <tuffty/>
    Dec 2011
    630
    <tuffty/>
    Yeah you have mate was reading on your thread about the vvt from the link you gave me thanks again man.
    was just unsure of the sai as my mate who is going to be doing the work was asking to try get the heads up before the work starts
    i would imagine all gaskets would be same part numbers ?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    Yeah... gaskets are the same...
    <tuffty/>
    Dec 2011
    630
    <tuffty/>
    yes mate Stacey said its coming timed up
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,098
    Will be all new bolts, seals and gaskets used but will be all same bearings and rings as bores look lovely and bearings look fine (end of the day most components are less than 2 years old and with 10k or so on them)
    I will and have replaced and rectified anything I feel needs to, or have any doubt with, hence ripping the whole thing to bits just to get the block decked
    <tuffty/>, Sandra and Goubo1 like this.
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,098
    Managed to get the head assembled this morning
    Lots of pics as promised
    Quick parts pic
    Just took plenty of photos during the assmebly
    Changing exhaust camshaft seal
    Inlet cam seal
    Timing marked up with a paint pen as makes life easier
    Lifters in and lubed up for exhaust cam
    Head all assembled, will chuck more lube on once all bolted to the block
    If this afternoon goes ok will get started in the block
    Dec 2011
    630
    Looking good dude :-) thanks for the pictures
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,098
    Got some more done today
    Gave the block another clean in the wash tank and gave all the oil galleries a good blowing out as the block was cleaned in an ultrasonic cleaner prior to machining
    Crank bolted in
    Pistons and rods going in
    Made new TDC marks (lightly scribed with marker to highlight) for if you shall ever want it and prefer having it there myself
    Just reallised that i haven't got a spare set of plastic cam covers so will have to transfer yours if ok once recieved the engine? The cam cover is just an old one had knocking about and if your running push down coilpacks then will have to just switch it over to your one
    I also presumed you wanted a sump with an oil level sensor?
    If any different just let me know mate
    Sandra and Sam_ like this.
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,783
    Nice job
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,273
    Becoming a good little engine builder Stace
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    I hate this with all the envy in the world
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,098
    Cheers guys am hoping Rob enjoys the engine as much as I have over the 4 years of owning it
    Its definately getting easier now working on these 1.8t's as have stripped 6 and assembled 4 of these engines now lol
    Dec 2011
    630
    Crank bolted in
    Sound mate,yeah oil level sensor is sound thanks for the pictures :-)
    Dec 2011
    630
    i hope so to stace :-),will speak to you tomorrow mate
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,098
    Thats cool mate if you can think of anything else then let me know
    Fitted the N/A head gasket in the end so CR should be over 9.0/1 now
    Nov 2012
    Kent
    459
    Add Tim_Attard on Facebook
    looks good, would love to be able to rebuild an engine
    http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/187166-tims-max-power-a3.html
    Quote Originally Posted by 16Klappe View Post
    Don't listen to him Tim, You're my hero, I'm proud of you.
    Dec 2011
    630
    is there anything you can think of mate as I ain't to sure only thing is the apy manifold I have.
    what is the ideal compression ratio ?
  28. #27
    JudderMan's Avatar
    Nov 2012
    Newcastle Upon Tyne
    744
    Why did you paint the block black? Thought the common idea was to have anything but black to be able to check for any oil leaks. I know that you don't want oil leaks but it makes it easier to see if the block was silver for example.
    2000 Audi A3 1.8T Sport AUM K03S|Second owner|Forge 007p|CM TIP|Yellow Dogbone|Pipercross panel
    To Fit - Decat then Mapping WANTED: Audi A4 B7 or MK5 Golf GTi (manual)(Want to Buy December 2014 so Keep Me in Mind)
  29. #28
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,098
    Quote Originally Posted by Goubo1 View Post
    Will repeat what was discussed in texts...
    Can either port the small port mani to largeport like superkarl is currently doing (pics in his build thread) or get a phenolic transition gasket
    The tip has only a 40mm port for the dv which is pointing towards the throttle body for a coldside relocation and the n75 port as had deleted the evap/charcoal canister and done the pvc simplification by fitting a catch can
    Found an old pic of the tip for you
    You will obviously need to transfer all your ancillery equipment across as i took it all for my new engine, just to reclarify its the long block and the turbo conversion with related stuff (tip, injectors etc) will be getting
    You should be fine to run it with the bigger tip and the engine belongs are on actuator only (with it set sensibly) as you have got a map for the main hardware but from personal experience the mtm map didnt cope well with the extra flow on mine so best to wait until you get it mapped properly for the hardware
    Also i would be checking your fuel pump condition before pushing it as wouldn't be supprised that your pump was struggling and possibly caused your engine failure (only stipulation but worth checking as don't want it happening again)
    Sorry to rabbit on a bit but thought it was worth clearing it up and trying to give you a better picture of whats needed to fit it all etc
  30. #29
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,098
    Also forgot to say that compression ratio is definately better being higher within reason, unless your running a stupidly large turbo then not worth running low comp
    Most people are aiming between 9.0/9.5-1 this block should now be somewhere in the middle of that figure
    In theory you should achieve more power than what i ever achieved as i was running 8.5-1 cr
  31. #30
    Dec 2011
    630
    i will get a gasket then I think,I've been told I had to keep everything from mine as I would need all my sensors an such so should have all that.
    fuel pump Is a good shout what is the best to replace it with ? A oem pump ?
    Not a problem mate I'm grateful for any advice or pointers :-)
  32. #31
    Dec 2011
    630
    see when you made 335bhp was that with meth?
    as I'm planing on 3" downpipe large tip and jetex and mapped to suit.
    hopefully I prove the theory right sometime soon :-)
  33. #32
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,098
    When bill mapped it meth was on there but was mapped with it or even dyno'd with it so there is also more to be had there as well
  34. #33
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,098
    7Pump wise you will need to log and see if afr is leaning out and injector duty cycles are reasonable to make sure your ok on actuator
    Bill will soon be able to tell you if your pump is dying when he turns the boost up when mapping
    Personally I would replace the oem if need be and get an uprated pump inline as you are going to be chasing for more with some form of hyrid at a later date anyways
  35. #34
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,098
    Right all is pretty much ready to be sent up to you mate
    Changed the cam chain tensioner over for you
    Engine pretty much sealed and has since been wrapped in black cling film (although have forgotten to put cak pos sensor back on but will sort that)
    Pretty much everything packaged bar the DP
    All the turbo lines
    Affraid I have found a hairline crack in the wastegate valve seat so will have to use yours or if you want will try and source one from vag or scrappy?
    The wastgate is perfectly usable but the little ring/valve seat just comes out and is a seperate piece
    Drop me a text or something to let me know what you want
  36. #35
    Dec 2011
    630
    All the turbo lines
    Looking good :-),gave Stacey a call and just sorting out payment so hopefully get it fitted this weekend :-)
  37. #36
    Dec 2011
    630
    Payment sent to the email address you supplied mate :-)
  38. #37
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,783
    I'm so jealous. That engine looks really nicely done.
    I bet your dying to get it in
  39. #38
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,098
    Cheers Sam
    We had a few hicups last night due to paypal being a complete arse and deciding thst they want to hold the money
    After about 100 texts and couple of phone calls and a mrs with the hump that I wasn't packing boxes ready for the move everything went through
    Pleasure dealing with you Rob and hope this lives up to your expectations and more
  40. #39
    Dec 2011
    630
    Quote Originally Posted by Sam_ View Post
    yes mate I'm desperate to get it in :-)
  41. #40
    Dec 2011
    630
    Cheers Sam
    that hiccup with PayPal was crap lol had me a bag of nerves lol,
    was great dealing with you mate and can't wait to receive the engine.
  1. back on the road... finally, and a transformation... to a monster!!
    By ian 06 A3 2.0 tdi s line in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st October 2010, 22:38
  2. My S3 is back on the road!
    By s4mark in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th January 2010, 13:46
  3. So, I get back to the UK this morning to this....
    By OutLore in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th July 2007, 06:50
  4. Replies: 6
    Last Post: 4th April 2007, 08:41
  5. Yeay back on the road after 4 weeks in its own puddles!
    By ianhg in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th July 2005, 19:56
