Sky InsuranceEM Tuning
Results 1 to 8 of 8
    Oct 2012
    17
    Tyre rubbing on coilovers..HELP!!
    Hi guys I've just recently stuck jom coilovers on my audi a3... The problem I'm having was the tyre rubbing on the adjuster ring..so I put 5mm spacers on yesterday and drove it for about ten miles and it was fine...but then I grounded out on my mates street and now the anti roll bar is rubbing on the driveshaft, accommodating with a high pitch squeal and the front tyres are rubbing against the adjuster again where should I go next? 10mm spacers on the front? What? Had enough already its lowered 60mm on the front and rear
    Any advice will be a help
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,591
    Too low....
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,591
    ...in all seriousness... you can try larger spacers but chances are the tyres will then rub the arch instead... seeing as the platforms screw down to lower then you need to raise the suspension a bit to ensure the platforms miss the tyre...
    As for the ARB, this is also a common issue when lowering an A3 (All mk4 platform cars using the over the driveshaft type ARB suffer from this)... again the solution is typically raise the suspension a bit... you can also buy adjustable drop links that will raise the ARB a bit... this hs been discussed quite a few times here as its a common issue..
    <tuffty/>
    Oct 2012
    17
    Cheers mate I raised the front by 20mm and its stopped the tyre scrubbing the adjuster ring but my anti roll bar is still rubbing on the driveshaft but only the near side?? Basically just seeing what adjustable anti roll bar links you guys recommend cheers
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,591
    Oct 2012
    17
    Cheers... Just read on another thread mate that adjustable don't help??? Summit about a whiteline arb to solve the problem?
    Shaunie Eire's Avatar
    Aug 2010
    Ireland
    72
    Spacers and roll the arches? You can do what I did in the mk4 and just cut out the ARB :0 but Id only recommend that if you are going all out slammed( Helpers out, No adjusters etc out back). Dont bother with adjustable droplinks they dont work the majority of the time. You can get an ARB with a larger loop or get an r32 one and get a competent welder to retro fit a bracket onto your coilovers, The R32 ARB goes under the drives, If you plan on going any lower you will also need a chassis notch otherwise your drive will be like this
    IMG_0130 by ShaunieRal, on Flickr
    I would also advise a sump guard or shallow sump, The sumps are crap and will crack very easily.
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    TT ARB will stop it rubbing as it goes under rather then over the shaft.
    i had to fit 20mm spacers to stop rubbing on the front.
    Audi A3 8L 1.8T breaking.
    front bumper, impact bar, slam panel, full engine and loom sold.
    everything else for sale.
  1. Coilover help.
    By floyd 1.8 turbo in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th June 2009, 12:23
  2. Rear Tyre rubbing help
    By ruairi83 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th February 2009, 19:51
  3. Tyres rubbing @ full lock
    By doeboy in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th January 2007, 23:19
  4. Tyre rubbing on cornering.
    By SanityClause in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th October 2004, 01:43
  5. Tyre wear ,can you help please
    By domcj in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th December 2003, 19:02
