EM TuningChris Nott
Thread: gear 1 and 2
    baldyplayer99's Avatar
    Jun 2012
    east sussex
    79
    gear 1 and 2
    my s3 has sometimes got tempermental 1st and 2nd gears. the other 4 go like that clappers and are smooth and normal. but 1 and 2 are blocky, sometimes abit clunky laggy. Is my gearbox knackered? clutch?
    im booked in at parsons performance next week to get a health check but just curious if anyone had this issue before
    ive also got a under rattle on the car. only sometimes on start up. and always when i bumping along 1st and 2nd when in traffic it will rattle when i take my foot off the accelrator and slow down. like a vibration sort of rattle. no noise i can hear when driving normally
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,280
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Probably your linkages....
    It's pretty common on our cars tbh for 1st and 2nd to be difficult to engage- but should get easier after the cars fully warmed up.
    Have you got an uprated dog bone mount? That's a good option to go for.
    When are you off to Bens as well- I need to get mine booked in now you mention it! lol
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    Jun 2012
    east sussex
    79
    is it going to cost me a lot if it is linkages lol... and tbh it does get better the longer you drive but still can tell it isint 100%
    i havent changed the dog bone myself and no indication on paperwork.
    next friday 3pm
    kwistof's Avatar
    Jun 2010
    SE Kent
    2,280
    Not 100% sure on costs of refurbishing the gearbox with new linkages...
    I blew my gearbox up just after Christmas so got a second hand one for about £200 and got Ben to fit it in a day. So doubt it would cost more than £500 really.
    Uprated dog bone mount would be the cheapest/easiest fix to see if it reduces the vibrations and help select gears 1 and 2.
    When I got mine done I felt an improvement but it didn't make it 100% perfect.
    2000 S3 APY
    May 2013
    21
    Quote Originally Posted by baldyplayer99 View Post
    My 1st and 2nd are slightly notchy too but otherwise fine. Not sure what it is, my thoughts are worn synchros but wouldn't worry unless it stops working! Rattle is prbably the heatsheild as mine had that problem. The bolts that hold it on had rusted so we put a small bolt through the rear area to nip it tight and it's fine now.
    kwistof's Avatar
    Jun 2010
    SE Kent
    2,280
    next friday 3pm
    Just got booked in from 10am....so depending on how quick Ben gets through my stuff I may see you there
    2000 S3 APY
  1. 2.5 TDI Quattro Gear and Diff Oil
    By BlackQuat in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th May 2010, 22:37
  2. Stiff gears and no Reverse
    By awfmaster in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th September 2009, 12:26
  3. S3 Rev'ing its self between 1.k-3k when not in gear, and very hesitant
    By VTI_EG_DAN in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th April 2009, 17:44
  4. Replies: 0
    Last Post: 22nd October 2007, 15:57
  5. changing gear and diff oil
    By pt7550 in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th May 2007, 22:18
