    Steven.c's Avatar
    Auto-Motive Restored Deatail
    Sep 2011
    Shropshire - West mids
    282
    vag com fault codes. help please?
    Hi, i have a audi a3 1.8t AUM fwd. lately the car has been acting strange so i scanned it and it came back with these faults.
    Address 01 -------------------------------------------------------
    Controller: 06A 906 032 FC
    Component: 1.8L R4/5VT G 0002
    Coding: 11500
    Shop #: WSC 02629
    WAUZZZ8LZ1A041577 AUZ7Z0Y1605717
    2 Faults Found:
    16486 - Mass Air Flow Sensor (G70): Signal too Low
    P0102 - 35-10 - - - Intermittent
    16804 - Catalyst System: Bank 1: Efficiency Below Threshold
    P0420 - 35-00 - -
    Readiness: 0000 0000
    Address 03 -------------------------------------------------------
    Controller: 1C0 907 379 E
    Component: ESP FRONT MK60 0103
    Coding: 0019970
    Shop #: WSC 06435
    1 Fault Found:
    01164 - ESP Operation
    008 - Implausible Signal - Intermittent
    Address 17 -------------------------------------------------------
    Controller: 8L0 920 980 E
    Component: AB-KOMBIINSTR. VDO D12
    Coding: 00444
    Shop #: WSC 00088
    1 Fault Found:
    00562 - Sensor for Oil Level/Temperature (G266)
    30-00 - Open or Short to B+
    Unsure on the MAF one as i have only just replaced it the day before with a genuine bosche one?
    The esp one is the one that worrys me the most as it flashs up on the dash and its like the brakes go strange and abs kicks in?
    any help would be much appreciated
    many thanks
    steve
    Metallic Ming Blue a3 1.8t sport.
    K03s, Revo stage 1, Jetex(JR) filter, Silicone TIP,N249 Bypass, Forge Split-r'seee
    Mk3 GTI Project - < Click me
    May 2012
    RETFORD, NOTTS
    1,703
    Did you try clearing them first as they are all intermittent and the air mass one could be due to changing it.
    I have the same oil light, sometimes it works sometimes it doesnt, likely the senser in the sump, £90ish to replace from stealer iirc.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
  1. VAG COM Fault Code Advice Please.
    By Fahd in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th March 2011, 21:47
  2. VAG COM fault codes - help please?
    By Geeman in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th June 2009, 08:54
  3. vag com fault codes..... any help out there please?????
    By shufti in forum VCDS (formerly VAG-COM) forum
    Last Post: 12th March 2007, 03:43
  4. Vag com Fault code
    By craig_007 in forum VCDS (formerly VAG-COM) forum
    Last Post: 9th December 2006, 22:03
  5. VAG-COM Fault Codes
    By imported_VaulterTim in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th January 2006, 08:00
