Volks AutosJMB Retrofits
    Mar 2013
    25
    AKL 1.6 power loss, slightly jerky acceleration, won't rev past ~5,600
    Hey all,
    my '99 A3 has recently (last week or so) started displaying a behaviour wherein it seems to be a bit down on power (not dramatically so, but I notice it), especially in lower revs and sometimes hesitates for a moment when I press the throttle. If I go to run through the gears, power falls off like I hit a wall at around 5,600rpm. It drives ok, but…
    Briefly tried disconnecting the MAF (though didn't disconnect battery or anything) which made everything substantially worse.
    Coolant temp sensor, thermostat and timing belt were all changed a couple of months ago.
    I'll get it checked with a vagcom as soon as is feasible, but does this sound familiar to anyone?
    S
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    889
    Add Vex182 on Facebook
    Possible vac leak? A VCDS scan like you said would be best.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Jun 2011
    Great Melton Norfolk
    1,356
    being non turbo vac leak wouldnt have that much effect,.When was fuel filter/air filter last changed?
  1. Slight power loss
    By brent 3045 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd April 2012, 15:08
  2. Slight jerky acceleration
    By Japper in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd August 2010, 08:55
  3. Help / Advice needed, A3 1.8T, Power blipping /slight loss of power
    By Lex007 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th August 2009, 09:49
  4. Power loss on acceleration VAG 17428
    By troubled in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th July 2006, 19:42
  5. Power Loss On S3
    By dans3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th May 2003, 15:06
