Sky InsuranceChris Nott
Results 1 to 23 of 23
    Apr 2012
    Wiltshire
    164
    AFR readings with my car, are they correct?
    Basically I have fitted myself a AFR gauge a few months ago. I have always noticed a humming noise when driving along motorways etc. But I have always put this down to tyres or gear box. I have noticed for example when my car is at idle it does not just stay at 14.7 but I continuously fluctuates between 14.7-15.1 and back. Now it also does this when I am cruising along the roads at a continuous speed giving a two tone noise from the engine that I thought was the gear box at first. Now I have a standard fuel pump in the car, 111k on the clocks now, and running a 4bar reg. could this issue with the AFR going up and down slightly be due to the fuel pump being tired? any other suggestions to the possible cause?
    16Klappe's Avatar
    Princess Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,082
    Visit 16Klappe's Instagram Channel
    Potential air leak, always worth having a smoke test done.
    AFR will fluctuate slightly as the ECU adapts to the airflow and the atmospheric differences, 14.7 to 15.1 isn't a bad fluctuation though so I wouldn't be overly worried.
    What does it read on boost?
    I quite often say I'm going to do things.
    Then never do them.
    Mar 2012
    96
    as above thats normal ! what matters is what afr is under boost
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,522
    Why do you have a 4bar FPR in there?
    Have you checked block 32 in VCDS to see what LTFTs are?
    16Klappe's Avatar
    Princess Slayer
    Sep 2008
    Basingstoke
    5,082
    Because it is an S3 Mark
    Back to the A4's you go
    Then never do them.
    Apr 2012
    Wiltshire
    164
    Have you checked block 32 in VCDS to see what LTFTs are?[/QUOTE]
    Hi, sorry I don't know what your mean?
    No air leaks, when I took the car to B5 for the custom map all air leaks were checked. But if they are suppose to do that then that's fine. I thought that they had to hold a constant reading of 14.7 on idle. On full throttle I think it around 12.5ish, which I have read is fine.
    With the cars AFR changing while cruising its creating that two tone engine noise in sequence with the reading going up and down, so this is defiantly normal?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,591
    Quote Originally Posted by 16Klappe View Post
    A4's typically came with 4bar fpr as std while transverse engines like the S3 have 3bar so his question is valid...
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,591
    4bar fpr on a std car with make the ECU pull around 15% fuel out... absolutely no reason on the planet to fit one and if you think your pump is suspect then even less reason to use one as this will send it over the edge..
    Do as Mark suggests... use VCDS, log it on block 31 (assuming its wideband... lets face we have no idea what car/year etc you have or if it is std or not as you haven't mentioned this)
    fluctuating AFR is fairly normal... if your car is mapped and its doing 14/15s on boost then its a crap map <end/>
    If all you are worried about is cruise etc then don't worry... fuel pumps show signs of weakness under boost when they are forced to earn their living...
    If not mapped for the 4bar (assuming its std) then bin off the 4bar for a 3bar and save whats left of the life of your pump...
    <tuffty/>
    Apr 2004
    12,522
    Back in your box Jardo,
    You 8Ls just want to own a bit of the B5, so you steal our FPR's However our pumps can manage it no problem and they are designed to because they left the factory like it
    16Klappe's Avatar
    Princess Slayer
    Sep 2008
    Basingstoke
    5,082
    Our A3 pumps can manage 4 bar....On boost
    I knew that A4's/Passats had 4 bar regs, our friend Robin with the Scirocco I was talking about the other day didn't know that and was running a 4bar FPR on a standard map with a 3 bar pump.
    Poor lad.
    Then never do them.
    RIP S3dave
    May 2004
    nr Glos
    7,181
    Quote Originally Posted by Dan s3 audi View Post
    what engine code S3?
    why 4bar as others have asked...........
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    Apr 2012
    Wiltshire
    164
    <tuffty/>
    Car Spec as follows:
    B5tip
    Large port head
    low comp wossner pistons (I know I would have been better off with normal comp but at the time jabba sport said to put high comp in)
    re-bore to 82.5 bores
    rifle drilled intergrated rods
    4 bar reg (again jabba said not to get bigger injectors but put the 4bar in, bad advice I know)
    stage 3 spec ko4 cr turbo
    relentless v2 mani
    3" straight exhaust de-cat
    bored out inlet manifold
    welly cooler
    forge re-circ valve
    Not a wideband ecu (old version)
    Was mapped at jabba before last Christmas and had problems with map. Took it to bagger this year where he produced 305bhp from it. When on full bost its around 12.5-13mark, when cruising with no boost alternating between 14.7-15.1.
    16Klappe's Avatar
    Princess Slayer
    Sep 2008
    Basingstoke
    5,082
    Under fueling slightly I believe, Bill and PT will be able to comment better but on the face of it I believe there should be roughly 1 part less air on full throttle.
    Then never do them.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,591
    Ah... k.. I have vague recollections of the car now lol... sorry dude, see so many cars
    Old non wideband lambdas are not the most accurate and depending on the actual map (all things considered) then I am not sure its something to be overly concerned about... tricky one to diagnose easily over a forum... maybe worth dropping Bill a call and see if he can dig up your dyno runs to see whats what... he may well remember the car once you prompt him...
    Where is the lambda for the wideband gauge?
    As mentioned before AFR does tend to fluctuate a bit especially seeing as the hardware setup is a little more exotic...
    <tuffty/>
    Apr 2012
    Wiltshire
    164
    <tuffty/>
    That's okay, I know you must see a lot of cars go through bills workplace a week. I have a dyno print out with the afr readings when it was mapped. I will post them on the next post, when I have uploaded them. The afr gauge, which is a wideband, is placed on the de-cat pipe because I didn't have the resources to weld a new point on (just used an existing point). My main concern was the two tone noise when keeping at a constant speed from the engine. just like the engine is making a deeper then a lower tone. (which is consistent with the afr gauge going higher and lower).
    Apr 2012
    Wiltshire
    164
    Jabba's map
    B5 map
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,591
    Humm.. an exhaust leak could cause fluctuations too... its quite far from where the normal readings are taken...
    <tuffty/>
    RIP S3dave
    May 2004
    nr Glos
    7,181
    B5tip
    Large port head
    relentless v2 mani
    welly cooler
    forge re-circ valve
    To further complete the Information, now I know what car this is.... You have sorted your Fuel Pump Issues now?
    afr ins 12.5:1 is ok, if its rising with revs higher than this, then its max'd injector duty cycle and or running out of fueling
    Remind me,.... your injector size is??
    www.badger5.biz
    bill@badger5.co.uk
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    lol
    im gonna guess stock bill
    RIP S3dave
    May 2004
    nr Glos
    7,181
    lol
    yea, but this car has had different stuff done to it...
    386cc std injectors @ 4bar ~440cc equivalents, which will max out at just over 300bhp.
    550's for the win on 3bar fpr ideally as my preference
    fuel pump(s) also have been an issue.... but I dont remember the details..
    www.badger5.biz
    bill@badger5.co.uk
    Apr 2012
    Wiltshire
    164
    Hi bill
    Nothing at the time was mentioned about the fuel pump, it was all running sweet at the time. They were standard injectors and still are atm. I am to come back to you with my new 550cc injectors and 3bar reg for a car check. This has been put on hold at the moment as I have just brought my first house and all my savings are drained lol.
    RIP S3dave
    May 2004
    nr Glos
    7,181
    Hi bill
    you had an inline pump but it was noisy so you were'nt running it? I think thats what I remember.. thats why I mention fuel pump.
    houses = bigger money pits
    www.badger5.biz
    bill@badger5.co.uk
    Apr 2012
    Wiltshire
    164
    Yes just working out my monthly bills for the house and its not looking good for the Audi lol. but its like with my motorbike, I re-built both the engines myself and put so much time into them I would not sell them off. Rather they sat in my garage until I have enough money to run them.
    Nope, I only had just the standard fuel pump on the car.
  1. A3 2.0T maf readings Are they any good?
    By A3Craig in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th February 2013, 17:40
  2. Help please new Osram bulbs fitted (are they in the correct place)
    By fozworth in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 30th January 2011, 20:47
  3. AutoVolks are they good people to deal with?
    By iModA3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th July 2008, 17:00
  4. are they taking the p!ss with petrol prices now or what!!!!
    By audi80sport in forum Rants & Raves
    Last Post: 20th October 2007, 04:47
  5. MOT tomorrow, what are they going to try and scam me with?
    By FrankScorpio in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th July 2007, 18:37
