Volks AutosMonster Motorsport
Page 2 of 3 FirstFirst 123 LastLast
Results 41 to 80 of 93
Like Tree21Likes
Thread: Gizmo's S3 8L round two...
  1. #41
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,560
    Those clips are a ball ache... this may be of interest...
    http://www.audi-sport.net/vb/group-b...-a3-s3-8l.html
    <tuffty/>
  3. #42
    Gizmo20VT's Avatar
    Jun 2012
    289
    <tuffty/>
    I saw the group buy, not sure if its still one but its in working order now :D!
  4. #43
    Mar 2013
    South Africa
    242
    Quote Originally Posted by Gizmo20VT View Post
    I wanted to use server cabinet clips like my first headlight but after looking at the actual clip it would need some distance for the motor to move when adjusting so it would just pop out... Do you have S3 headlights?
    No they are the standard A3 lights... The projector globe is much larger on mine than on the S3's... The clip I used was roughly the same size as the plastic ones and would sit the same distance as the plastic ones so I'm happy! Also I don't have motors to adjust the light level so that must make a difference.
  5. #44
    Gizmo20VT's Avatar
    Jun 2012
    289
    Other headlight finished up this weekend, stopped at my local dealership to collect some small bits and bobs that are missing :D
    Yesterday at Sidey's house we did boost leak tests and I found my TIP has a tear in it... At the bottom where it tightens onto the scroll so need to get a replacement for that...
  6. #45
    Apr 2013
    JHB, South Africa
    168
    Nice cap! I have the exact same one
    Gizmo20VT likes this.
  7. #46
    Gizmo20VT's Avatar
    Jun 2012
    289
    Not much happening currently as we just purchased our first house and moving in month end! Will finally have a garage to work in
    Got some small updates for now, Installed most of the AEM watermeth kit, Tank is located in the rear quater similar to what miggz did and controller and arm switch in the lower dash panel under the steering. I layed the festo piping in the car... I just need to do FMIC then I can wire up the pump and install the nozzle.
    Test fit
    Brackets
    Plumming
    Used the old rear sub connector block so I could remove the lower panel with no hassles
    Lower panel reinstalled
    Also remove the Preamp out the stock woofer enclosure an put it into a casing I had lying around to keep the rear speakers alive.
    Then ill be replacing the Vibe Liteair splits located in the front with some SPL Dynamics SD5.2 so A-pillars will be redone.
    Sidey likes this.
  8. #47
    Oct 2012
    South Africa
    268
    Awesome work as always bud.
  9. #48
    Apr 2013
    JHB, South Africa
    168
    Top stuff bud. And congrats on the house man.
  10. #49
    Gizmo20VT's Avatar
    Jun 2012
    289
    Thanks guys :D
    So moved into our new home on the 1st of this month, and finally got around to finishing up my WMI installation, Pump installed just need to wire it up which is tonight mission. Might also rotate the pump 180 degrees tonight.
    I used engine cover brackets and bolted it down in the other rear quater panel, Some pics...
    will finish up tonight then I just need to wait for FMIC to install the nozzle :D!
    PDBoosted likes this.
  11. #50
    Mar 2013
    South Africa
    242
    Nice work bud! Small steps at a time
  12. #51
    Oct 2012
    South Africa
    268
    Awesome work as always, love the attention to detail.
  13. #52
    Gizmo20VT's Avatar
    Jun 2012
    289
    Ye dude, in no rush Still have a set of these to install and another blower intime...
    PDBoosted and Kuvi-S3 like this.
  14. #53
    Gizmo20VT's Avatar
    Jun 2012
    289
    Quote Originally Posted by Sidey View Post
    Shot boy! When we doing rear diff?
  15. #54
    nanananananananan BATMAN
    May 2012
    JHB, South Africa
    1,081
    Add MIGGZ on Facebook
    very neat dude! thinking of maybe moving the pump to the boot as well cos of thee race tank now
    My rides thread : http://www.audi-sport.net/vb/a3-s3-f...t-journey.html
    Quote Originally Posted by Paradox1 View Post
    Healthy??? no,no,noooo
    Mine is healthy
    yours is on steriods!!!
  16. #55
    Oct 2012
    South Africa
    268
    Yeah we need to make a plan soon bud.
  17. #56
    Gizmo20VT's Avatar
    Jun 2012
    289
    Quote Originally Posted by MIGGZ View Post
    Thanks dude! I wanted to mount in engine bay but after going over the instructions for Snow, AEM and Devils-own I decided rather to keep them as close as possible as they mentioned if you mount the pump in the front you would need a additional solenoid to feed it.
    MIGGZ likes this.
  18. #57
    May 2012
    JHB, South Africa
    1,081
    yeah when i originally did mine they also said i might need a solenoid but after Carl said he never needed one i decided to just go with it, the delay without the solenoid is like 1 to 2 seconds so i just lived with it. iv also installed a 1 way valve in the line between nozzle and pump
    Mine is healthy
  19. #58
    Gizmo20VT's Avatar
    Jun 2012
    289
    This weekend was pretty much car weekend :D Put in some good hours on the engine bay even thou it still looks the same lol!
    First up removed most of the PCV system to start with the catch can install and gave the intake and injectors a good scrub, also replaced intake gasket, personally I think its the wrong head on my car
    Injectors & Manifold all fresh
    Then it was time to relocate the N249 so opened the coilpack harness up and pull the N249 wires back, mounted and out of the way.
    Fuel lines replaced and kinda look oem :P
    Installed my powerflex bushes on dogbone quick
    My car has had lifter noise when warm since I have purchased her, So Sidey came over yesterday to aid while we serviced the Intake lifters and having a few beers... Getting my new gaskets today and Torx set and I broke two of mine trying to remove the cam caps Pretty fun job
    Busy stripping the lifters apart
    Time to oil and reassemble, Tonight I shall retorque the cam caps and start smoothing my valve cover before it goes in for powder coating :D
    More updates laters
  20. #59
    Errrr
    Mar 2013
    South Africa
    166
    Das good ya! Nice jersey btw
    2002 8L A3 1.8T (264WHP / 412NM)
  21. #60
    Gizmo20VT's Avatar
    Jun 2012
    289
    Quote Originally Posted by Ashley =1.8T= View Post
    Keeps me warm and makes me look Saxy, I have my famous two tone pants on aswell LOL!
  22. #61
    Apr 2013
    JHB, South Africa
    168
    Awesome work as always dude
  23. #62
    Gizmo20VT's Avatar
    Jun 2012
    289
    Quote Originally Posted by Kuvi-S3 View Post
    Thanks bud :D
  24. #63
    Mar 2013
    South Africa
    242
    Nice work as always bud...
    PS I'm glad you didn't have to sell her!
  25. #64
    Gizmo20VT's Avatar
    Jun 2012
    289
    Thanks bud :D
    Thanks man, you and me both! Almost regreted buying house...
  26. #65
    Gizmo20VT's Avatar
    Jun 2012
    289
    After doing lifters I got stuck into the valve cover and started smoothing it out, removing all the studs and valve cover brakets. Will send the intake, valve cover, strut brace and Throttle body in next week to power coat.
    Will be using Red and sandpaper matt black.
    Will update when done
    Scullies likes this.
  27. #66
    Gizmo20VT's Avatar
    Jun 2012
    289
    And hopefully monday I have another parcel arriving which was paid for today! Can not wait!!!!
    MIGGZ likes this.
  28. #67
    Apr 2013
    JHB, South Africa
    168
    Going to look awesome!
  29. #68
    Mar 2013
    South Africa
    242
    Thats going to look epic!
  30. #69
    Oct 2012
    South Africa
    268
    Looking good brother, Gonna be even better with the new package fitted.
  31. #70
    Apr 2013
    JHB, South Africa
    168
    Guys, hows about an update on this "new package" or is it top secret for now?
  32. #71
    Gizmo20VT's Avatar
    Jun 2012
    289
    Thanks buddy
    Quote Originally Posted by PDBoosted View Post
    Dankie Chom!
    Lol its nothing huge, and wont make me go faster :P
  33. #72
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Thanks buddy
    Dankie Chom!
  34. #73
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    If it doesn't make you go faster or stop quicker then there is nothing to see here ............
  35. #74
    Mar 2013
    South Africa
    242
    I know what it is Going to be awesome once fitted!
  36. #75
    Errrr
    Mar 2013
    South Africa
    166
    +1
  37. #76
    Gizmo20VT's Avatar
    Jun 2012
    289
    Just had these delivered :D! Pretty stocked to install them
    BC BR Coilovers
    Sidey and I will tackle them one night after work quick!
    Ashley =1.8T= likes this.
  38. #77
    Errrr
    Mar 2013
    South Africa
    166
    Finally got them love these
  39. #78
    Airs's Avatar
    Jan 2013
    142
    BC BR Coilovers
    i just got a set of these for my TT im building, they are an awesome piece of kit arnt they, cant wait to get to use them
  40. #79
    Gizmo20VT's Avatar
    Jun 2012
    289
    Ye they are epic dude, keen to see how the ride will be vs my old AP coils
  41. #80
    Airs's Avatar
    Jan 2013
    142
    yeah they are, i dont really have much to compare them to other then my cheap fk setup on the bora, but that things is constantly slammed so no comparison really lol
  1. N75J.... Which way round ?
    By nradfo01 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th May 2004, 08:10
  2. two for one
    By chippie in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th October 2003, 07:51
  3. new tyre needed - do i need two though?
    By comdw in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th September 2003, 13:56
  4. Replies: 5
    Last Post: 1st April 2003, 10:24
  5. WHICH WAS ROUND SHOULD A DV GO?
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd February 2003, 14:41
