AH FabricationsVolks Autos
    Boost fiend
    Dec 2008
    Swansea
    207
    AGU Boost question
    Hi folks, picked up another 1.8T sport today.
    AGU
    k03s
    Turbo back exhaust with sport cat
    FMIC
    Has an induction kit
    Dv (have suspisions it may be fake 007p)
    guy says it's not currently mapped to stage 2, on boost gauge it says it's boosting to 6-7 psi, does this seem right?
    car pulls pretty well, doesn't feel mapped though, I have got my old CC stage 2 ECU lined up to go on.
    is there any way of checking part number on turbo when in situ to confirm it is correct k03s?
    i do trust him, and have the old k03 in a box too, just want a second opinion on it.
    99' A3 1.8T Sport KO3s Custom Code stage 2 - Current
    99' A4 1.8T Quattro Sport 180 - Sold
    97' A3 1.8T Sport KO3s 236 BHP - Sold
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,231
    get under and check part number would be the only way, other then taking the TIP off and looking at the intake side for the number of fins
    6/7 PSI is standard map IIRC
    Audi A3 8L 1.8T breaking.
    front bumper, impact bar, slam panel, full engine and loom sold.
    everything else for sale.
    Boost fiend
    Dec 2008
    Swansea
    207
    Cheers mate, I'll try have a look under car at part number on turbo.
    he said it had been mapped, but if its only boosting that then I suspect maybe not. It would still be boosting the same even with ko3s, if its on standard map won't it.
    Would a boost leak give me a lower boost reading on the gauge?
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,054
    part number on the blue tag will show, ko3S will be ko3-052 /053 / 058, you'll typically only see 052/3 though.
    Otherwise, whip the tip off and count the fins.
    standard map by the sounds of it, nice and ready for a st2 map as well!
    Jan 2013
    If it helps .... I have an AGU with a KO3S, Forge 007 and induction kit .... I get 8-9 PSI boost with standard exhaust and no map
    Boost fiend
    Dec 2008
    Swansea
    207
    Cheers guys. Had a little look at turbo, can't see part numbers on blue plaque but is had a silencer on the cold side of the turbo, only ko3s has that iirc?
    so 6psi sounds is about right for standard map? Will check for boost leaks before I fit ecu with stage 2 map. Changing oil pickup first as a precaution to make sure it's ready.
  1. KO3 boost questions
    By Oranoco in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th December 2008, 23:38
  2. Boost questions...
    By Beerzo in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th August 2006, 10:58
  3. Boost question to chipped s3's
    By s3withproblems in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th August 2005, 08:08
  4. Another Boost Question
    By h3msy in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th February 2005, 08:19
  5. AMD REMAP - Boost question
    By jayfrts in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st July 2004, 19:21
