Chris NottBadger5
Like Tree3Likes
  • 3 Post By 16Klappe
Thread: forge recirculating blow off dump valve
    Mar 2013
    Blackburn, Lancashire
    17
    hi
    I have a mark 1 audi s3 thinking of buying a forge recirculating blow off dump valve. has anyone got one fitted or know if it will make the noise.
    If you have one fitted how good does it sound?
    Tom
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,557
    You get more noise from more boost pressure (remap) and running an aftermarket filter (open cone or panel filter...)...
    The valve (regardless of if its OE or Forge recirculating) makes no real difference...
    And don't bother with a split-r or any type of atmospheric valve...
    <tuffty/>
    16Klappe's Avatar
    Princess Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,061
    Visit 16Klappe's Instagram Channel
    Ground.Hog.Day.
    **** my life.
    superkarl, Vex182 and Stuart35205 like this.
    I quite often say I'm going to do things.
    Then never do them.
    epox's Avatar
    Oct 2012
    Glasgow
    584
    think the general comments are stick to the standard vag recirc valve
    Aug 2011
    Plymouth
    744
    Add Lavis89 on Facebook
    general opinion is stick to the OEM valve, they're good up to 30psi i believe, forge recirc valve is pretty much just engine bay bling, needs to be serviced every year so is a bit of a false economy buying one (although i have one myself) .
    that's what i've gathered from people on here anyways but lots of people will have different opinions.
    and yea, dont bother with atmospheric blow off valves or split valves
    2001 1.8T Quattro Sport 89k covered ARY engine.
    Remapped at Badger 5, 213bhp - 235lb/ft torque.
    HS2K cone, FMDV008, Silicon TIP, 18" RS4 (reps), AP coilovers, Catch can, n249 bypass, Toyosport 3" Downpipe/Decat, S3 Front brakes, Polyflexed Dogbone, S3dave adjustable tie bars
    Soon to be done: SAI delete, Install the toyosport FMIC i have kicking about in my living room
  1. Blow Off / Dump Valve - A3 2.0 T FSI S-Line Spec. Edition - Is it worth it??
    By Dave_2.0T in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st December 2011, 21:37
  2. Hesitation after forge spacer fitted. is dump valve faulty?
    By chrisa4quat in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 22nd September 2011, 17:45
  3. Forge Splitter R Recirculating Blow Off Valve 1.8T
    By Turbo Lag FTW in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th February 2009, 20:22
  4. Replies: 5
    Last Post: 9th February 2007, 17:46
  5. Forge Motorsport blow off valve.
    By terrymcg in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd January 2007, 17:04
