Results 1 to 18 of 18
Like Tree2Likes
  • 2 Post By Prawn
Thread: Engine's transfer
    May 2011
    stocton-on-tees
    64
    Engine's transfer
    Hi all I have a A3 1.8t agu engine for sale and a friend has asked if it will go in a A4 1.8t as his has snapped the belt. So he would like to put the block and head in and use his turbo and manifolds will this work.
    Thanks all
    16Klappe's Avatar
    Certified S3 Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    4,899
    Visit 16Klappe's Instagram Channel
    Yup all exchangeable. There are differences with the cam cover which is worth noting when doing the swap.
    I quite often say I'm going to do things.
    Then never do them.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,354
    Nope, won't go. 058 and 06a different enginers, mounts won't swap over, different flywheels and clutches
    Dec 2012
    Ireland
    29
    Yes it will, a buddy done same conversion it was a 06 a4
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,899
    How certain of that are you?
    Why won't the mounts swap over? Friend of mine used a Passat engine in his Mk2 Scirocco, I was sure the blocks were the same.
    Then never do them.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,021
    Quote Originally Posted by 16Klappe View Post
    the 058 block used in the A4 is derived from early VAG 2ltrs (ABF etc) you pillock lol... fancy asking if Marks is sure... LMAO!!!... he has forgotten more about A4's than you actually know... ;P
    Transverse is 06A block, inline is 058... do some research...
    <tuffty/>
    Apr 2004
    12,354
    How certain of that are you? 100%
    Really you want to get into this?
    The later a4 is based upon an 06b unit which shares the same mounts but is alloy block.
    058 block is external waterpump and almost identical to the KR/ABA style block and as such will drop in on the same mounts but you have to use the flywheel and clutch from the donor. If the 06a unit is used then you need to use mounts from an ibiza to make it fit. I would get technical and produce pictures but can't be bothered.
    Sell it to your mate, Jardo says it will fit, I'm sure he knows best....
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,899
    So they do fit then with the right mounts?
    Then never do them.
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,062
    Robin bought an 058 block because he couldn't find a decent priced 06A.
    As it happens, it's bloody lucky he did, because the mounts are totally different, and the 058 went straight in using OE mounts on the engine side.
    Had he followed the plan and bought an 06A he'd have had a whole load more work and had to make up mounts.
    So yea, they're pretty different.
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,899
    But in short...they do fit.
    Then never do them.
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,062
    NO!!!! FFS dude. let it go.
    Sam_ and m19lte like this.
    Apr 2004
    12,354
    in the boot yeah. Not under the bonnet and connected to the chassis with bespoke work to get it into the A4.
    As stated the A4 one will go into the rocco as will the 06a with the right mounts, there is no such thing as the correct mounts to fit the 06a into a b5. If you use B6 mounts you are opening another actual can or worms, all this for a cheap engine, AEBs are like £200 complete nowadays.
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,899
    [Rant]Nope, I refuse now. Mark and PT are having a huge case of unnecessary PMT, as are you actually.
    A simple explanation could have done, but nope...that's not the ASN way. People are allowed to run around asking the same freaking questions every single day, but Jardo doesn't understand why a bit of hard work and adaptions mean something can't be done and BOOOOOOOM like a ton of bricks.
    #nottheonlypersonwhosaysorthinksitcanbedonesowhyno tasktheguyabovewhoclaimstohavedoneitratherthanbein garseyaboutit
    *awaits being removed from discussion*
    Xxx[/Rant]
    Cheers for the explanation Mark. NOW I understand.
    s33nyboy12's Avatar
    May 2012
    East midlands
    1,281
    Lol lol lol now that's entertaining! :-)
    Current: 2013 Audi A3 2.0 tdi s line 8V in black SD nav+ extras, E46 BMW M3, 1971 Volvo p1800, 2014 Ford transit sport 155ps ;-)
    Previous : Focus st 225 stage 1 (265 bhp and too much torque), 2002 audi s3 bam engine completely OEM, 2001 Audi a3 1.8 TQS 221bhp and about 20 other cars, majority civics ek4/ek9 and Bmw / Audi soot chucker's!
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,899
    Indeed, entertainment is my middle name.
    Then never do them.
    Apr 2004
    12,354
    Not the word running thru my mind.....
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,062
    Really?
    So the second post wasn't simple enough for you?
    Quote Originally Posted by Byzan Pics View Post
    Quit your whining.
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,899
    It's you doing the whining.
    Don't think that just because you're power to weight is up I won't kick your ass. I'm a black belt, this one gang wanted me to join because I've got skills with a bow staff.
    Then never do them.
  1. Audi's Engines
    By amoffat in forum Other Brands & Models
    Last Post: 14th March 2003, 08:50
  2. Disapointing engine sounds
    By Simon in forum General Chat
    Last Post: 21st January 2003, 18:59
  3. Audi engineering info
    By Mutley in forum General Chat
    Last Post: 6th January 2003, 14:32
