EM TuningBadger5
Results 1 to 7 of 7
    Jun 2003
    Bromley
    305
    A3 cutting out - any help appreciated.
    'lo everyone. Having another issue with my A3 1.8T sport. just recently it has developed an annoying fault, it just cuts out whilst driving. All the electrics work, dash stays lit, just the engine switches off. When you try and restart it, it turns over but wont fire up. Leave it a couple of minutes and a few tries later, it starts up and away we go. IT is coming up for a service, has had a new ecu recently but im baffled as to what could cause this problem. HAs anyone else experienced similar problems before?
    Markb's Avatar
    Apr 2004
    Midlands, Staffs
    2,136
    Re: A3 cutting out - any help appreciated.
    Haven't you been having this problem for a while now? I thought it was something to with your ECU? Maybe something to do with the Super Chips map on it?
    Numptie of the highest order
    Jun 2004
    Crowthorne, England
    2,512
    could be an over heating or blocked fuel pump, not sure though but it might be worth checking.
    Jun 2003
    Bromley
    305
    Mark, the problem you mean is an old one, which was sorted with the new ecu. Car is no longer chipped and has previously, and still does, drive very well. Just a wierd problem and a frustrating one at that, as id rather it didnt do it in the middle of the M4 in a couple of weeks.
    Timbo's Avatar
    Slowest car ever round the Top Gear track?!?
    Dec 2004
    Surrey
    275
    Dodgy fuel pump cutoff? It's supposed to activate in the event of a crash but I've heard of them triggering inappropriately on other cars.
    Or have you got an aftermarket alarm & immobiliser? It could be immobilising when it shouldn't if the wiring's gone awry - i.e. if the wiring's worn through somewhere it might think someone's trying to disable it.
    Jun 2003
    Bromley
    305
    just like to add that now the audi alarm is having a habit of going off when trying to unlock the doors, starting to think the audi alarm is going wrong and that it might be the immobiliser kicking in when it shouldnt...
    Jun 2003
    World of my own
    9,813
    Or the ignition reader coil is worn out. I get this on my 97 A4. Every now & then it'll start then immediately cut out. When this happens, I just put the key in slowly and leave it in the ignition for a few seconds before starting.
    there was a write on here in the A4 section about a cheap fix for this problem, but I never got round to it as it only happens maybe once a month.
