Volks AutosBadger5
Results 1 to 22 of 22
Like Tree1Likes
  • 1 Post By 16Klappe
Thread: uuurgh three codes and epc light... problem after problem!
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    hey all the list of problems ive had with this s3 in the 2 months ive owned it is getting silly...
    now the brakes are sorted and we've established im running a standard map im getting the epc light on! intitially i had two codes yesterday and after cleaning the trottle body and recalibrating she ran fine for half an hour then three codes... cleared them then came back ten minutes later then twice more on the way home. if i turn the engine off then on it runs fine for anything from 2 to 10 min then back on!
    16622/P0238/000568 - Manifold Pressure/Boost Sensor (G31): Signal too High
    Possible Symptoms
    • Malfunction Indicator Lamp (MIL) active
    Possible Causes
    • Wiring/Connector(s) from/to Manifold Pressure/Boost Sensor (G31) faulty
    • Manifold Pressure/Boost Sensor (G31) faulty
    Possible Solutions
    • Check Wiring/Connector(s) from/to Manifold Pressure/Boost Sensor (G31)
    • Check Manifold Pressure/Boost Sensor (G31)
    16725/P0341/000833 - Camshaft Position Sensor (G40): Implausible Signal
    Possible Symptoms
    • Malfunction Indicator Light (MIL) active
    Possible Causes
    • Wiring from/to Camshaft Position Sensor (G40) faulty
    • Camshaft Position Sensor (G40) faulty
    • Timing misaligned
    Possible Solutions
    • Check Wiring from/to Camshaft Position Sensor (G40)
    • Check Camshaft Position Sensor (G40)
    • Check Timing
    18047/P1639/005689 - Accelerator Position Sensor 1/2 (G79/G185): Implausible Signal
    Possible Symptoms
    • Malfunction Indicator Light (MIL) ON
    • Reduced Engine Output
    Possible Causes
    • Wiring and/or connections faulty
    • Faulty ECM
    • Faulty Accelerator Pedal
    Possible Solutions
    • Check Measuring Block Readings for Accelerator Pedal
    • Check Voltage Signals from ECM to Throttle Pedal (see factory repair manual)
    • Check Wiring and Connectors from ECM to Accelerator Pedal
    Special Notes
    • There are 2 sensors in the accelerator pedal, both should increase in the same direction as the accelerator is pressed but they have different scales. This means one counts from 0 to 100, while the other one counts from 0 to 50.
    • Accelerator Position Sensor faults can be caused by issues with the Oxygen Sensor(s) and it's wiring. Please verify this BEFORE replacing the ECM or Accelerator Pedal. Accelerator Pedal failure is very rare.
    these must all be linked somewhere... surely, any common problems that are likely to throw all three codes?
    also wondering if my v3 relentless has caused damage to the lambda wireing after that last bit on the accelerator code!?
    1999 apy s3, n249 delete, sai and n112 delete. bbs lm reps, s2000 filter, relentless v3 manifold, relentless downpipe and sports cat, scorpion cat back system, badger 5 v3 tip, bam rocker cover, push in coilpacks, toyosports fmic, amd remapped to 280.3 bhp and 263.9 lb/ft.
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    are these all earthed together? also could one going cause the other two too show faulty? cant believe all three have failed on the same day, search through the posts on here and cant find any with the same three codes? im thinking it must be a wireing issue or water in the ecu, was raining hard all day yesterday, is the ecu in that white box near the wiper mechanism?
    16Klappe's Avatar
    Princess Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,082
    Visit 16Klappe's Instagram Channel
    MAAAAAAAAAAAAAFFFFFFFFFFF SSSSSSSSSEEEEEEENNNNNNSSSSSSOOOOOORRRRRRRR.
    superkarl likes this.
    I quite often say I'm going to do things.
    Then never do them.
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    love you klappe!? guess your pretty sure then?
    16Klappe's Avatar
    Princess Slayer
    Sep 2008
    Basingstoke
    5,082
    Disconnect the MAF, reset the fault codes, take it for a drive.
    If only the EPC light stays on and you get a MAF code I would be mightily confident. When the MAF is disconnected or has totally failed the EPC light comes on and the car resorts to a preset table of control based against the rpm rather than the constant adaptions it would normally make. Perfectly safe to drive with the MAF disconnected in most cases.
    Then never do them.
    RIP S3dave
    May 2004
    nr Glos
    7,177
    Quote Originally Posted by justarn View Post
    ecu lives in scuttle to the right of centre as looking at it.. not the white box no.
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    RIP S3dave
    May 2004
    nr Glos
    7,177
    Quote Originally Posted by 16Klappe View Post
    his code is>> 16622/P0238/000568 - Manifold Pressure/Boost Sensor (G31): Signal too High
    MAP sensor... not MAF
    Is this how you read it dude?
    www.badger5.biz
    bill@badger5.co.uk
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    yeah thats right, also made no difference with maf disconnected ecp still came on... cleaned the maf and after it dried ran for 5 miles ok before throwing the manifold one and throttle one again?
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    erm i think it said pressure too high intermittant? just cleared them again and parked her up behind the two farm gates i have to go through, think that makes it worse keep undoing the darn gates lol....
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    how does the scuttle come off, i dont want to break it? guessing wipers off then pull some hiden clips upwards?
    gotta be worth a look right?
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    also had all three codes plus maf and engine speed sensor no signal aswell with the maf disconnected!?
    after that when i reconnected and wiped she ran for 5 miles ok?
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    you saying map sensor could be the cause of all this bill? just got the ecu plugs off an wd40'd em... lost a bloody wiper cap, flew off at 1000mph somewhere, doh!
    16Klappe's Avatar
    Princess Slayer
    Sep 2008
    Basingstoke
    5,082
    You have got a hardware issue somewhere, potentially MAP sensor then.
    As far as I am aware there is no way around diagnosing a faulty MAP sensor other than replacing it, with it unplugged **** just gets ****ed up and the car will kangaroo and drive lumpy. If it isn't the MAF as I suggested then you really need to talk to a specialist and have the car logged and a fault finding session. MAF sensors cause a lot of the problems you have mentioned, past the MAF there isn't really any suggestion which can be made reliably.
    There isn't a perfect 1.8t in the land, every single one has a slight boost leak, an under reading MAF or whatever else. Don't let it get you down.
    Then never do them.
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    i guess we're stuck then.... so the map sensor could cause the throttle position code aswell?
    where is the map sensor, is it the little one near the throttle body on the front? whats its name g31 sensor?
    RIP S3dave
    May 2004
    nr Glos
    7,177
    no I did'nt say that
    for multiple sensors to all have issues at same time its most likely electrical, earth connection, power, fuse gone etc etc..
    several earths terminate under and around battery area..
    you need a wiring diagram to know whats shared between these sensors etc
    www.badger5.biz
    bill@badger5.co.uk
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    cheers bill, where are the fuses... also i did notice sometime the epc was coming on when i turned right so maybe earth is a good shout...
    i clean the ecu connectors just now pluged her all back in, got about 4 more codes and she was running worse than ever, the throttle peddle wasnt doing a thing and the revs were hunting around 1100rpm and the car sounded like a bag of bolts.....! not good, disconnected the battery and tapped the negative a few times now she's purring like a kitted with no codes!!?
    odd one, must be earth surely
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    would like to add to this, when the car was running lumpy and the throttle wasnt working i deleted the codes and then my vcds flashed up as disconnected came back then read no fault codes while it was running like that for a couple of minutes so im guessing the ecu lost power?
    another thing ive noticed today my electric windows work but the click to go right up or right down dont work???
    i had the battery out half hour ago, removed, cleaned and refitted all earths i could see. i removed the panel in the drivers footwell and fuse box and the carpet where the bonnet catch is looking for any obvious faults,,, none found. checked the fuses, all ok.
    be back out there tomorrow, if anyone has any suggestions please post up... did wonder about the battery or ecu being faulty?
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    883
    Add Vex182 on Facebook
    To make the one click windows work, when they are both closed, hold the left window button up towards closed for 3 seconds then the right for 3 seconds, then when you press down on either, it should drop as normal.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    cheers vex
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    just found this so i'll be checking the map wireing as i was messing around near is a few days ago!
    Help, I've killed my car!
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    ok im gonna rule out fuse after checking them all, inc the one under the dash... im thinking because they are intermittant its either a break in a wire or an earth... or a sensor failing. if its the map sensor failing i think its my fault, when i refitted my turbo i slightly overfilled and she's spat oil through the tip and intercooler pipes, its pretty oily in there. tryed to get the map of yesterday for cleaning and dropped the little screw driver bit dow behind the headlight into the abyss!
    also as i wrote in my last post i was messing around near the map sensor the other day trying to find a place for the pipe i removed from the airbox when fitting the s2000 filter, so i could easily have broken one of the wires...
    think i need a voltmeter today, sounds fun eh!
    does anyone know where the map and other said sensors (camshaft, engine speed, throttle position) share an earth?
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    whatever ive done its been fine today??? touch wood this isnt a recurring problem....
  1. A3 esp and steering lights on after smash
    By dallo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th April 2013, 13:15
  2. Help! Esp and brake lights on after DIS and cruise fit
    By rob irl tdi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th September 2010, 15:59
  3. ESP and EPC Light Staying On And Engine Revs Up & Down??
    By pazaz in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th March 2010, 20:34
  4. Engine, Traction and EPC light
    By stevehall in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 25th November 2009, 19:20
  5. 1.8T ESP and EPC lights have come on
    By M4KTT in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd December 2008, 01:39
