Monster MotorsportEM Tuning
Results 1 to 8 of 8
    Mar 2010
    Killarney, Ireland
    75
    S3 Rear brake upgrade or repair.
    I have a 2000 S3, and have an issue with the rear brakes. The handbrake section of both the rear calipers are seized and even with the handbrake continuously off the rear brakes don't fully release. While the calipers aren't leaking the pistons have some corrosion on them so it's only a matter of time, the pads are shot and need to be replaced and the discs are in no great shape either but will do if I have to leave them there and have the option to skim them. The brake fluid has been changed.
    I tried removing the rear discs for a closer look but they wont budge (and yes I have removed the bearing nut and locating screw), if I use anymore force to try and remove the rear discs I will definitely have to replace them. The rear subframe is heavily corroded so I'm presuming they are being held on with rust.
    With all this in mind, for the rear, is there a better caliper and disc setup that is used. I have heard of changing front calipers for Passat ones as they have better braking force with a slightly bigger piston, but is there anything like this for the rear.
    Would be intersted if anyone has thoughts on this before I go down the route of replacing the piston and seals in the calipers, changing the pads and probably the discs too.
    Mar 2010
    Killarney, Ireland
    75
    Anyone have any views or thoughts on this???
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,223
    In terms of upgrading the calipers mate theirs nothing really out their without spending £££'s, id get the calipers refurbed and fit with a good quality discs and pad.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,461
    Std rear brakes are more than adequate for the S3.... there is very little braking bias to the rear to prevent it swapping ends... there are larger disc 'upgrades' available... but these are on the basis of upgrading the front to larger discs to retain braking bias...
    Larger pistons will only give you a longer pedal... not really an 'upgrade'.... there is brake info (inc rear disc upgrades) in the stickies..
    <tuffty/>
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,435
    New pads discs and refurb calipers is what I would do in your position.
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,254
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Quote Originally Posted by jojo View Post
    What's the best grease to use to refurb the callipers with? My rear ones a tad sticky and needs sorting
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    Mar 2010
    Killarney, Ireland
    75
    Thanks lads it's the answer I was looking for, I've the seal kit, pistons, discs and pads on the way. I'd read through the stickies but it wasn't giving me an alternative to what I'm going to be doing.
    Mar 2010
    Killarney, Ireland
    75
    Quote Originally Posted by kwistof View Post
    I take it you're only greasing the caliper sliding pins. I clean the pins with a fine wire brush and then I use a thin coat of Molykote 1000 paste on them before reassembly.
  1. Decent/worthwhile rear brake upgrade
    By Ryanc in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th December 2005, 19:17
  2. rear brake upgrade on a6
    By dummi in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 8th October 2005, 17:42
  3. 1.8t rear brake upgrade
    By tomijee in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th May 2004, 18:34
  4. About rear brake upgrade.
    By Theodore in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th January 2004, 07:51
  5. Replies: 7
    Last Post: 3rd January 2004, 19:52
