Chris NottAH Fabrications
Results 1 to 17 of 17
    Oct 2011
    greater mcr
    108
    mass air flow issue
    Hi folks, my esp light has come on and vagcom won't clear the fault !
    It's a 2002 s3 8l (recently put a 06 bam engine in on amk ecu) vagcom fault code is coming up with : 16486 - mass air flow sensor (G70) signal too low P0102 -35-00
    Any ideas ? As I've only 12 or so month ago replaced the maf for a new genuine unit, anybody know what configuration of the wires/plug ? To church the voltage so-on ? Cheers
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,529
    Check your wiring, the plug might have broken plastics, it happened to mine!
    Oct 2011
    greater mcr
    108
    Yea I have mate, as it happens the red sort of retaining clip inside the connector had broken up !?! But it doesn't foul the connector in any way !and it still plugs in fine, what did u do ? Did u just replace the sensor ?
    Sep 2010
    Devon
    752
    I'm having the exact same issue, can't for the life of me work out what the problem is, just gone through every bit of wiring i can find and every earth point. Doing my head in. If you find the answer tell me and i'll tell you if i get there first lol
    Badger 5 tuned 340 bhp / 350 lbft sleeper
    Oct 2011
    greater mcr
    108
    No worries bud will do ;-)
    www.badger5.co.uk
    May 2004
    nr Glos
    6,944
    and the maf is "ok"?
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Sep 2010
    Devon
    752
    Yes for both. Although personally as soon as my maf is plugged in it cuts out, did the same with a brand new genuine bosch maf as well. Pretty stuck!
    Sep 2012
    West midlands
    368
    You erasing the maf fault before puting new maf on?do you get the fault code before you start car or after?
    Audi s3 8l 2003 silver,brembo brakes,custom front mount intercooler,forged rods,acl race bearings,3inch tip,forge 007p green spring 1 shim,5mm hubcentric spacers,pipewerx 3inch down pipe/200cell race cat,2.75 miltek back non resonated,new piston rings,n249delete,pcv venting too atmosphere,neuspeed quick shifter,uprated clutch/pressure plate...large port agu head,inline fuel pump
    work left/relentless v3 manifold/wmi/blue haldex/antilag/launch controll/custom map!!!!!
    Sep 2010
    Devon
    752
    Fault code is cleared before sticking the new maf on,start the car code comes back, clear the code, try and drive and as soon as the revs drop car cuts out.
    Sorry to the op if this is a hijack but hopefully it'll all be relevant
    Sep 2010
    Devon
    752
    Thats me sorted!! I got fecked off and dissasembled the 4 pin plug that connects to the maf, connected the spade end pins inside the plug directly to the relevant pins in the maf plug itself and bingo!! Off to tps to pick up a new plug Hope this helps and you get it sorted quickly mate
    Oct 2011
    greater mcr
    108
    Sorry folks only just seen this, been really busy. What I ideally want to know is what voltage should the maf plug be kicking out ? As I want to check the voltage first-to see if there's a break in the wire soon.
    If the voltage is fine then I will replace the maf.
    Nice one slowcoach 3, pleased for you, do you have a part no or description for the plug ?
    Oct 2011
    greater mcr
    108
    Oh n don't be sorry, it is all relevant ;-)
    Sep 2010
    Devon
    752
    I have an etka print out but not to hand, i'll stick it up tomorrow, has all part numbers on it Sorry don't kbow voltages, electrics is not a strong point of mine!
    Oct 2011
    greater mcr
    108
    Great stuff cheers pal
    www.badger5.co.uk
    May 2004
    nr Glos
    6,944
    bill@badger5.co.uk
    Oct 2011
    greater mcr
    108
    Cheers Bill just what I needed, thanks
    Mar 2012
    Any news on this M19lte
  1. Mass air flow sensor - S3 (8P)
    By warren_S3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd April 2008, 09:55
  2. mass air flow meter for TDI
    By andyollie in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd August 2005, 08:12
  3. Mass air flow
    By rafA4 in forum General Technical / How To
    Last Post: 7th March 2005, 12:18
  4. Bora TDi 115 Mass Air Flow?
    By DunnerDan in forum Diesel forum
    Last Post: 28th February 2005, 14:10
  5. Mass Air Flow Sensor
    By darrenp in forum Diesel forum
    Last Post: 4th December 2004, 14:38
