Chris NottAH Fabrications
Results 1 to 33 of 33
Like Tree6Likes
  • 1 Post By basil brush
  • 1 Post By 16Klappe
  • 2 Post By superkarl
  • 1 Post By s33nyboy12
Thread: Starting to hate my car and running out of ideas
    Jun 2012
    Redhill Surrey
    629
    Add Grale1 on Facebook
    As some of you may know I have issues with a left hand pull, I'm at a lose to get to the bottom, I've had hunter alignment done, replace both ball joints, both track rod ends, both inner tie rods, and got fully poly bushed wishbones and changed to coilovers.
    I'm running out of idea as what it could be, I thought maybe rack but it doesn't leak. Took it to a garage today and spent a couple of hours looking over the underneath, subframe doesn't look bent. Checked everything over, paid for another alignment as I put the poly'd wish bones on so they adjusted the toe as they say you can't adjust the castor or camber, to top it off there printer was running low on ink so I didn't get the "after" print out, I was standing next to them so I know they weren't telling a fib.
    Starting to wonder if the car is bent.
    All tyres are same pressure tread depth the same, wheels balanced correctly matching tread patterns.
    At a lose to what it could be.
    simon
    A3 1.8t AGU, fk ak street coilovers, silicone tip, silicone turbo outlet pipe, forge 007p ( yellow spring ), 80mm jetex cone filter, 3" cold air feed, 3" downpipe and de cat, R-tech stage1 map 187bhp- 227ft
    Mar 2013
    Chelmsford , Essex .
    198
    binding brake ?
    first thing that popped into my head !
    voorhees likes this.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,468
    Bent subframe
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,533
    Could be your rims?
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,645
    Could it be road camber giving the impression of steering problems ?
    Jun 2012
    Redhill Surrey
    629
    Def not road camber, I was going to ask a friend if I could try there standard wheels on mine. Not sure how to tell if a calliper is binding ( sounds stupid I know ). I was thinking front subframe as it drifts left when you coast also, you can feel the wheels twitching every now and then through the steering wheel, like wondering on the camber.
    Dec 2012
    Ireland
    29
    My car is the same, all bushings are ok , car is lowered and has slight pull to the left only thing is I don't have the rear adjustable arms so its pulling , otherwise it handles like a dream
    16Klappe's Avatar
    Certified S3 Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    4,906
    Visit 16Klappe's Instagram Channel
    If it pulls to the left it doesn't handle like a dream.
    A3's as stock cars were designed to lightly pull incase the driver fell asleep, they were designed to eventually take you off the carriage way. Shouldn't be noticible though.
    If it has had a four wheel alignment and was all ok it shouldn't pull, at all. So you have an issue somewhere. Are both front tires the same size? Are the track rods fitted on the right side? Have you replaced the subframe bushes?
    I quite often say I'm going to do things.
    Then never do them.
    Dec 2012
    Ireland
    29
    It has a slight pull ,not as severe as grale's car but I'm impressed with its handling ; )
    Mar 2013
    198
    If its had four wheel alignment and still pulls it isn't suspension related surely ?
    Still putting my money on sticking caliper on the left
    May 2013
    redditch b98
    230
    Add bradh on Facebook
    i know this might sounds daft but have u got a pair of wheels u could try on the front just a couple of spares or something like that
    also are your tires directional if fitted on the wrong way they can cause similar issues
    Jun 2012
    Redhill Surrey
    629
    Klappe, the front tyres are the same, ( AVONS ) and yes I replaced everything on both sides at the same time, and no I haven't changed the bushes in the front subframe or the rear axle, but I have noticed that the inside edge is wearing on the drivers side rear wheel
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,906
    Sounds fuuuucked
    Are the sills straight? When did the problem start? Bent rear beam/worn axle bushes is a possibility
    Then never do them.
    Jun 2012
    Redhill Surrey
    629
    I had the rear beam changed its been like it since I got it but seems to be worse now, one side of the rear beam looks like it sticks out more than the other ( drivers side ). Sills look ok, it's annoying as it seems to be quite common on golfs.
    I find it hard to let the car go, I like the shape of the 8l so may have to look round for another if I can't solve this puzzle lol
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,906
    Sell it, buy a DC2.
    s33nyboy12 likes this.
    Then never do them.
    Jun 2012
    Redhill Surrey
    629
    I couldn't afford to get rid at the moment lol, when I say it's bled me dry it really has bled me dry, I read somewhere about someone put the alignment gear from the front put on the back and back on the front and adjusted it to the rear axle and it worked??? Have my doubts about that
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,071
    You need a proper 4wa fook hunter ...everybody jumps on that band wagon..did you know you they have to know how to use it!!! you need to know the thrust angle and go from there ...if there printer is fooked tell them your money has vanished and do one.....
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,906
    Haha, thrust angle...
    Then never do them.
    Snash7's Avatar
    May 2012
    Horley surrey
    84
    Man its such a shame you havent sorted it pal. Saw you the other daynand the car is looking the nuts.
    I would help out but ive broken my wrist so cant drive apparently
    robloake's Avatar
    Mar 2013
    Hastings
    62
    Ive had a few tuned cars that all seem to do this, would it pull to the right if we lived abroad?? I think we get obsessed mate with every thing having to be on track especially when we've spent a few quid, are u happy with the motor in general?? every day I think is this right is that right but I still smile when I feel the torque, just go with it or sell it, what can you do???
    Jun 2012
    Redhill Surrey
    629
    Thrust angel is almost dead on, it was in green at 0.02, maybe it is torque if I had the money I'd fit an LSD. Yes I do like the car I like the colour.
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,645
    Check your brake pads for uneven wear.
    Jun 2012
    Redhill Surrey
    629
    I've checked the discs and pads, left rear seems to have a lip on the disc and the right side doesn't, I did look through paper work and the drivers side rear calliper was replace shortly before I bought the car, so could be a sticky/ knackered calliper as it pulls left also when braking, I think this is where I may look into more as I remembered the other week I had the car on stands on the back and the left rear doesn't spin as freely as the rear right,
    Mar 2013
    198
    Hooray after 22 posts since I suggested it you think it may be brake related !
    Sticky piston or slider pins , bet you
    Jun 2012
    Redhill Surrey
    629
    How would you go about unsticking the piston? I would of used cooper grease on the sliding pins on the carriers, the rear calliper piston if I remember rightly do you twist and push it to get it to go back in as if putting new pads in?
    Mar 2013
    198
    Silicone grease on the slider pins , yes the rear pistons wind back in and pop the front pistons out and clean them up if they are mankee
    baz
  28. #27
    justarn's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    589
    they are a bit of a sod to wind in, i done one recently... i levered with a wheel brace while the missus (need two people without the right tool) attempted to use!-) some parrot pliers to turn it clockwise, went in after 10 minutes of moaning at each other and her saying she cant lol.... bless her.
    1999 apy s3, black & blue interior,dare bbs lm's, s2000 filter, relentless v3 manifold, relentless downpipe and sports cat, scorpion cat back system, stock dump valve, badger 5 v3 tip, bam rocker cover and push in coilpacks, toyosports fmic, amd stage 2+ remap 280.3bhp 263.9 lb/ft.
  29. #28
    Mar 2013
    198
    The full left and right handed kit is £14 on eBay , just used mine for the first time to change my rear discs and pads and is a pukka bit if kit
  30. #29
    Mar 2013
    198
    And for those allergic to searches the item number is
    181138724429
  31. #30
    Jun 2012
    Redhill Surrey
    629
    Well passenger rear wheel spins round nicely, drivers rear doesn't spin freely and the tyre is mis shaped also, but I'm not sure if that could be the problem
  32. #31
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,906
    Yup, quite easily.
    Then never do them.
  33. #32
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,468
    Lets all sell our cars and get on with our ****ing lives eh.
    16Klappe and andy1571 like this.
  34. #33
    s33nyboy12's Avatar
    May 2012
    East midlands
    1,292
    The old saying " if its got tits or tyres its gunna cost ya" ;-)
    superkarl likes this.
    Current: 2013 Audi A3 2.0 tdi s line 8V in black SD nav+ extras, E46 BMW M3, 1971 Volvo p1800, 2014 Ford transit sport 155ps ;-)
    Previous : Focus st 225 stage 1 (265 bhp and too much torque), 2002 audi s3 bam engine completely OEM, 2001 Audi a3 1.8 TQS 221bhp and about 20 other cars, majority civics ek4/ek9 and Bmw / Audi soot chucker's!
  1. Car has reset and running like a dog
    By Tavman in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd February 2013, 22:45
  2. Car just cut out and won't restart! Please help!
    By Abb in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th January 2013, 23:43
  3. Knocking sound and running out of ideas!
    By Gratts in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th August 2012, 20:44
  4. Lorry scratched my car, and run away...geer
    By nvc in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th November 2009, 15:58
  5. 3.0 misfire problem - running out of ideas...
    By amiller001 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th January 2008, 16:15
