Monster MotorsportEM Tuning
    WorkInProgress's Avatar
    Oct 2012
    Scotland
    237
    Add WorkInProgress on Facebook
    Help! Coolant Leak
    Changed my thermostat and temperature sender tonight, seemed to go ok, went for a quick drive and the check coolant warning came on. Found this constant drip, any ideas what I've done wrong?
    https://www.youtube.com/watch?v=Ea-L...e_gdata_player
    1999 1.8t AGU Sport 150 5dr
    Fitted
    2.5" Decat Downpipe, 2.5" MeerKat Custom Cat-Back, R32 Wishbone Bushes, Black Diamond 12 Groove Discs, Phatnoise, S2000 Filter, HKS SSQV, BBS CH Rims,
    Koni STR.t Kit
    Awaiting Fitting
    ABT Rear Spoiler, Oettinger Grille, Catch Can
    Wanted
    5dr Black Leather Interior (Golf/Bora/A3)
    Plans
    Flocked Dash, Respray
    Oct 2012
    Scotland
    237
    Anyone???
    Fitted
    Koni STR.t Kit
    Awaiting Fitting
    Wanted
    Plans
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    695
    afraid you need to take it off and refit, maybe theres some grit or your missing a rubber seal not done it myself but just common sense mate.... when i done my downpipe i nearly forgot the gasket!-)
    1999 apy s3, n249 delete, sai and n112 delete. bbs lm reps, s2000 filter, relentless v3 manifold, relentless downpipe and sports cat, scorpion cat back system, badger 5 v3 tip, bam rocker cover, push in coilpacks, toyosports fmic, amd remapped to 280.3 bhp and 263.9 lb/ft.
    BENJAMIN's Avatar
    Mar 2011
    472
    The seal is dislodged or pinched. Remove it, dry the seal, put some grease on it and it'll stick to the stat allowing you to do it up without it moving around.
    '09 Lci 335d individual. M-dev stage 2, 360bhp 550ftlb. 'Undercover police edition'
    Oct 2012
    Scotland
    237
    Cheers guys, would it be worthwhile getting a new thermostat housing?
    Fitted
    Koni STR.t Kit
    Awaiting Fitting
    Wanted
    Plans
  1. 1.8T major coolant leak - your help please!
    By dope in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th May 2013, 09:36
  2. Coolant Leaking! Connector Piece Split - Help Needed
    By blloyd in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th April 2013, 10:27
  3. Coolant Leak... Help with part name/number
    By Maz in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd April 2012, 13:17
  4. Help! coolant leak after doing head gasket
    By neilmeagher in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th September 2011, 22:05
  5. help - water leak!!!!!!!!
    By ravi in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th October 2004, 08:39
