Monster MotorsportChris Nott
    May 2009
    19
    YAW sensor part numbers HELP PLS???
    Hey guys,
    I'm after a bit of help!?
    I've had the traction light on for ages on my S3 2001 facelift. Took it to a specialist who said the longitudinal sensor needs replacing. He replaced it but the light is still there. He is now saying that it looks like a signal problem from the YAW sensor. There's no way I want to spend £500 on this sensor so i'm thinking of getting a second hand one. Does any one know the part number for the YAW please? I know the longitudinal sensor sits on top/front of the YAW.
    Also is this a sensor which you can replace yourself? Does is need calibrating? Is it located under the steering column?
    Any help would be much appreciated
    s3mad_dude's Avatar
    Noggies ruuuule!
    Jan 2006
    Hampshire
    462
    I was always under the impression the ESP sensors were located behind the glove box.
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,283
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Some useful information here from a thread I remember reading-
    Dangerous YAW Rate Sensor Issue - 2001 Facelift 8L S3
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,640
    You need to scan it again to see why it's still on..
  1. Optics Grill part number help please...
    By Beddie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th March 2014, 19:28
  2. coolant temp sensor part number required
    By skanky in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th September 2006, 21:08
  3. MAF sensor Part number? anyone know?
    By MrCoont in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th June 2006, 09:57
  4. Part number help please
    By colinra in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th January 2006, 19:55
  5. Rain sensor part number?
    By olekvi in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th July 2005, 00:24
