AH FabricationsSky Insurance
Results 1 to 8 of 8
    Feb 2013
    12
    fault codes help needed!
    So on my other halfs aum 1.8t its had these 2 damm fault codes since buying it last year. 17705 air leak. And the other for sai incorrect flow
    So far i have replaced
    Maf
    Hockey puck
    all the hoses under the inlet with silicone jobbies.
    Recirc valve
    Spark plugs
    All filters
    Cleaned the tb
    Blocked off n249 and used silicone hose so dv is mechanically controlled.
    Still same damm fault codes. Car pulls well low down but goes really flat above 4k
    Cant find any split pipes or loose connections
    Any suggestions or help is welcome as im at the end of my tether now!
    Feb 2013
    12
    Btw all the replacement parts were genuine audi not pattern. Also to add the rev counter moves about slightly at idle. If i disconnect the maf it stays steady.
    Jun 2011
    Great Melton Norfolk
    1,340
    What make was the recirc valve?
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,528
    17705/P1297/004759 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
    Possible Symptoms
    Malfunction Indicator Light (MIL) ON
    Power Loss
    Possible Causes
    Leaking Hoses and/or Pipes between Components
    Boost Pressure Control Valve (N249) faulty
    Diverter Valve faulty
    Throttle Body dirty
    Vacuum leak
    Possible Solutions
    Check Hoses and Pipes between Components
    Check / Replace Boost Pressure Control Valve (N249)
    Check / Replace Diverter Valve
    Check / Clean Throttle Body
    Perform Throttle Body Alignment (TBA)
    Check for Vacuum leak(s) including PCV system
    Special Notes
    Did anyone install an extra (wrong) dump valve?
    When found in the NAR 2.0T (BPY) check RVUTB: 01-09-03 or 2018919 for updated Crankcase Breather Valve
    If the breather valve is faulty, full engine vacuum is typically found when removing the oil cap at idle.
    When found in the 3B B5/B5.5 Passat 1.8T, check the PCV "bleeder valve" for example part number 06B-103-245
    One way to troubleshoot the problem is to pinch closed the vent hose under the coolant bottle, that attaches to the bleeder valve and see if the idle smooths out.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    This is a known software bug in some ECU's... normally gets mapped out by decent tuners...
    <tuffty/>
    Feb 2013
    12
    Recirc was a new gen audi item from the dealer.
    Gops the 2 engines in the notes arent related to.my aum are they?
    Struggling to find a cause
    Feb 2013
    12
    Well she wants it remapped and so do i. Just wanted to get the new silicone tip and cat back exhaust fitted before getting it mapped at amd.
    They suggested they may be able to code out the sai so im going to remove it and fit a resister first. Just want to make sure theres no pressure drop before the map to make the most of it.
    Feb 2013
    12
    Bump for anymore suggestions
  1. fault codes help needed
    By Sham101 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th May 2013, 21:27
  2. Got few fault codes, help needed please as new to VCDS
    By JMB-S3 in forum VCDS (formerly VAG-COM) forum
    Last Post: 3rd December 2012, 01:31
  3. Fault code help needed 2000 S3
    By fitzdog88 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th April 2012, 22:17
  4. Fault code help needed plz!!!
    By shaz-raul in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 31st January 2010, 17:41
  5. misfiring fault, tech help needed - have vagcom fault codes
    By shufti in forum General Technical / How To
    Last Post: 16th June 2006, 22:14
