EM TuningBadger5
    Sep 2012
    48
    Vag Tacho Cluster Clocks Swap Tdi 1998
    Hi guys,
    Im attempting to swap my instrument cluster, I have a 1998 1.9 tdi, with analogue clock, Immo2, non-CAN and idiot lights!
    I have Vag Tacho and VagCOM, and have used the vag tacho to connect and retrieve my SKC from the existing clocks. I did this by connecting and choosing my ecu type, VDO old, and it connected to the ecu and extracted the code. I can then change miles etc. The clocks have VDO on the back.
    Now, I have purchased some brand new tdi clocks, which are IMMO2, can bus, but are not made by vdo, they have MM4 on the back. I dont have the skc for the new clocks, if indeed it has one as there brand new.
    When I plug in the new clocks, the all light up, and the car starts for a second before stopping.
    With the vag tacho in, I cant now connect to the ECU by choosing VDO Old. Nor can I connect via any other way, trying all the different types of ecu and clicking connect to ecu, or connect to any tacho.
    Now there are a million threads on all sorts of vag forums, mostly helpful, but none saying how to retrieve the SKC from new clocks when the vag tacho doesnt connect!
    Any help would be very much appreciated, I know the next step using vagcom to programme etc just need the ecu to talk to the new clocks?!?
    Old clocks part number 8L0919910D
    New Cluster p/n 8LO920950D
    Thanks in advance
    SL11CKK's Avatar
    Apr 2011
    Barking & London
    642
    Is your vagtacho cable genuine?
    Sep 2012
    48
    No, but it's done all the commands Ive asked of it on the current clocks. Not sure if I even need to skc from the new clocks, as I may just have to input the old clock skc through vagcom?
    Anyone done this before?
    May 2012
    RETFORD, NOTTS
    1,753
    Do you still need help with this?
    Ross-Tech: VCDS: Immobilizer 2 Instrument Cluster Swapping
    I can read your sck if your stuck but the dealer should supply i would have thought with new clocks?
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Sep 2012
    48
    I managed to get it going with what I have. Thanks again for the offer!
  1. A3 2.0 TDI Cluster/Clocks Needed
    By Eazyd in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st October 2012, 16:08
  2. Audi A6 TDI 1998 Wet Carpet
    By jonchold in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 4th March 2006, 15:38
  3. A6 Tdi 1998 Air Con
    By daver in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 2nd July 2005, 22:56
  4. Changing instrument cluster (clocks)
    By f13ldy in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th May 2005, 23:39
  5. ELECTRICAL PROBLEM ON A6 1.9 TDI 1998 >
    By imported_terry2wheels in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 26th August 2004, 19:29
