AH FabricationsEM Tuning
Results 1 to 11 of 11
Like Tree3Likes
  • 1 Post By Alex C
  • 1 Post By g60leigh
  • 1 Post By kwistof
Thread: Bearing or drive shaft?
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,392
    Bit of help please guys (and girls)
    After driving fairly hard tonight (Drag racing a marked police car from the lights) I have a rumble sound when doing low speeds. This sound changes slightly as I turn.
    I have had a quick grope under the car. (Have a better look tomorrow) had a feel of the movement on the drive shafts.
    There is no noticeable rotation or slop in the CV joints. There is some in and out movement on them (both sides) is this normal (I'm guessing so to allow for adjustment in length as suspension moves)
    Any other checks I can do or should I be looking more to bearing failure?
    Thank you.
    2001 S3 (AMK)
    AEM WMI Kit, Black Silicone Hoses, Badger5 TIP with Cone Filter, AH Fabrications FMIC, Relentless Manifold Downpipe & Sport Cat, Miltek Cat Back Exhaust, VAG Aero Wipers, Forge FMDV008 Re-Circ, Revo Stage 2 Remap with SPS+ Tweaks, 2.0 TFSI Coil Pack Mod, B&M Short Shift, RNS-D Retrofit, Brembo & B5 2 Piece Rotor Conversion
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,392
    Had a look this morning.
    Lifted car up and ........
    The ferking wheel is loose?
    Now had the wheels swapped over on Saturday. I was there when they did it and I watched them secure the wheel using a windy gun up until it hit its torque setting.
    Any idea why it would work loose?
    2001 S3 (AMK)
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,283
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Not to sure on why it would work loose.....sound very suspicious.
    How much do you trust the garage? Possibility the torque setting wasn't correct?
    Re-tighten them all up and take it for a drive and see if it's cured the issue. How loose was it as well? Finger tight?
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    Scullies's Avatar
    Feb 2012
    Dubai
    1,260
    Quote Originally Posted by g60leigh View Post
    geeez, lucky it didn't fall of this time. Check the threads on the bolts and holes
    May 2013
    21
    I had this on my citroen a few years ago - driving to work (London) and could hear a wobbling noise, realised the bloody wheel was loose and about to fall off! It was my own fault though, couldn't believe it. From then on I did the wheels up fecking tight!
    Alex C's Avatar
    Lizard, Cornwall
    2,606
    who won?
    AVLO likes this.
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,392
    Quote Originally Posted by Alex C View Post
    who won?
    I won 👍
    Alex C likes this.
    2001 S3 (AMK)
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,392
    Quote Originally Posted by Scullies View Post
    Threads are all fine. No damage done. That I can see.
    2001 S3 (AMK)
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,392
    Quote Originally Posted by kwistof View Post
    I was there when they fitted it. Using a snap-on windy gun.
    I trust the garage just wonder if torque setting wrong on his windy gun.
    It was very loose. Less than finger tight. Including the locking bolt.
    All tightened up by hand now and driven to work an back. No more noise 👍😀
    2001 S3 (AMK)
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    who won?
    He one and they even give him a certificate...
    kwistof's Avatar
    Jun 2010
    SE Kent
    2,283
    All tightened up by hand now and driven to work an back. No more noise ������������
    That's all good then...a tad worrying though as I hope that gun was re-checked for other customers as that could cause a serious accident.
    This thread sums up why you should always check your wheels bolts after 20 or so miles after taking the wheels off.
    g60leigh likes this.
    2000 S3 APY
  1. S4 Prop/Drive Shaft?
    By Phantom_A4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th January 2006, 16:35
  2. Drive Shafts...
    By darko in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th December 2005, 23:57
  3. whats a drive shaft boot? and how much to replace
    By imported_Yaseen in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th October 2004, 10:23
  4. vacuum pump / drive shaft
    By ajmackie in forum General Technical / How To
    Last Post: 9th October 2004, 20:44
  5. Vacuum source / drive shaft
    By ajmackie in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd October 2004, 03:30
