Volks AutosEM Tuning
Results 1 to 7 of 7
    May 2013
    surrey
    35
    1.8 to 1.8 agu engine swap
    hi guys im looking into doing an engine conversion on my standard 1.8 non turbo a3 and found someone breaking a mk4 golf with agu engine in it.
    just wondering what i would need for this conversion. obviously need engine, exhaust, turbo, gearbox, manifolds, driveshafts, ecu, clocks, keys.
    what else would i need
    would i need subframe
    anything else i have missed
    May 2013
    surrey
    35
    well £375 just got me a mk4 golf gti turbo agu engine, complete with subframe, gearbox, driveshafts,turbo, inlet and exhaust manifold, ecu, wiring loom, clocks, keys, front discs, pads, calipers. also thrown in full set of coilovers and standard mk4 gti turbo exhaust. im pretty sure i got everything apart from induction hose and filter and uprated dump valve. is there anything i need to make sure i got.
    Apr 2013
    21
    driveshafts i had to change driveshafts
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,523
    How did you get all that for £375?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,021
    What year is your A3 as this will make a difference too... don't see too many normally aspirated 20v's on here so not sure if you will have drive by wire or cable throttle as std...
    You will also be looking at wiring loom as there will be differences I would imagine...
    <tuffty/>
    May 2013
    surrey
    35
    got wiring loom and driveshafts from the golf. my audi a3 is a 1997 model running normal asp 1.8 20v
    May 2013
    surrey
    35
    guy on https://www.facebook.com/groups/Vagownersclub/?fref=ts who breaks v.w's for a living
  1. diagnostic port on agu engine
    By mlcadman in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th November 2004, 21:47
  2. Engine swap possible?
    By c_coffell64 in forum Tuning
    Last Post: 3rd November 2004, 08:09
  3. 4000 cs quattro engine swap
    By imported_SoVodka in forum Tuning
    Last Post: 2nd September 2004, 23:47
  4. Engine swap - need help with codes
    By Pincher in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th August 2004, 22:33
  5. Engine swap, is it possible?
    By 65coupe in forum TT/TT-S/TT-RS Forum
    Last Post: 30th December 2003, 06:29
