Badger5Volks Autos
Results 1 to 15 of 15
    Nov 2012
    15
    my s3 has started smoking :(
    hi i was wondering if anybody can help,a week ago i noticed after a puff of blueish grey smoke whilst starting my car at a petrol station over the next few days it seems to have got worse and worse,if its left to idle theres continuious smoke coming from the exhaust,id say its defo blueish colour,whilst driving theres nothing on boost or over run still nothing just when the car is at traffic lights etc ideling,anyway took it to the garage and he noticed that the breather hose going to the black pot on the right side of the engine had completely collapsed so i had all 3 breather pipes replaced and was told to run it over this weekend to see how it goes,but its still the same ive also noticed when the car is running if i unscrew the oil filler cap there is no noticable change in engine sound,it doesnt begin to die which i thought it would the revs dont even drop the slightest bit,any help would be appreciated
    XFi
    Jun 2010
    344
    It sounds like the turbo oil seals are on there way out. Removing the oil filler cap won't make a difference or cut the engine off, just spit oil out.
    Nov 2012
    15
    also what could i do to check to see if the seals have gone?
    16Klappe's Avatar
    Princess Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,061
    Visit 16Klappe's Instagram Channel
    Are you a mechanic? Would you be better to take it to a specialist?
    I quite often say I'm going to do things.
    Then never do them.
    Nov 2012
    15
    ive just taken the air intake off the turbo theres no sign of any oil in there ......
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    Check the exhaust side too
    Sep 2012
    West midlands
    368
    Quote Originally Posted by Scullies View Post
    you have possibly a leaking valve stem/seal...only does it when parked up and restarted (hot)?
    Audi s3 8l 2003 silver,brembo brakes,custom front mount intercooler,forged rods,acl race bearings,3inch tip,forge 007p green spring 1 shim,5mm hubcentric spacers,pipewerx 3inch down pipe/200cell race cat,2.75 miltek back non resonated,new piston rings,n249delete,pcv venting too atmosphere,neuspeed quick shifter,uprated clutch/pressure plate...large port agu head,inline fuel pump
    work left/relentless v3 manifold/wmi/blue haldex/antilag/launch controll/custom map!!!!!
    Nov 2012
    15
    if i start in the morning theres nothing noticeable coming from the exhaust after a couple of minutes ticking over it starts and is worse when warm, clouds come past when im in traffic,turn it off when its hot and start again then a puff of blue and then constant smoking,so for first couple of mins in the morning when its cold its ok
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Sounds like piston rings mate unfortunately,, or turbo seal exhaust side?
    Nov 2012
    15
    well came to start my car this morning,misfiring for about 10 seconds and beeeeep coolant level indicator is on,so now im losing water and gaining a misfire
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    Check the plugs if there is any coolant on them. You might have a blown head gasket.
    RIP S3dave
    May 2004
    nr Glos
    7,162
    opps.. sounds head gaskety now too then
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    robloake's Avatar
    Mar 2013
    Hastings
    62
    I remember when I started smoking............oh happy days
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    Quote Originally Posted by robloake View Post
    smoking from your exhaust? Party trick?
    robloake's Avatar
    Mar 2013
    Hastings
    62
    got some family in Dubai you guys have motor city cool there, green with the desert envy!!
  1. 2.5 TDI started smoking since service.
    By Ant1984 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 8th February 2010, 22:17
  2. Ahh Motorsport has started again
    By Gti Jazz Blue in forum Motorsport
    Last Post: 2nd February 2009, 15:36
  3. The work has started ;-)
    By yellowgti in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th August 2008, 16:32
  4. A3 1.8T conversion has started - pics to be posted
    By neversaydie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th January 2005, 14:42
  5. The war has started...
    By amoffat in forum General Chat
    Last Post: 24th March 2003, 12:24
