Volks AutosJMB Retrofits
    Sep 2012
    West midlands
    368
    S3 will not start???
    So I decided too for a da-31 pump fitted it with relay ect inline 20amp fuse and spliced trigger of wiring off the oem pump under back seat......
    took car out for a drive all ok went local scrap yard for a relay for my mates install drive home all fine misis goes too her mother in laws with the kids and I get a phone call saying car was spluttering do advised her too pull over and check pipes she knows the usuall suspects!!!
    i drive down In van started car up and it was misfiring violently so I cut it out disconnected maf same result after trying too start again no luck just turns over going over now with vcds too plug it in only code I did get off a crapy fault code reader is 1810 or somthing all I remember is terminal 30 voltage too low???tryed disconnecting fuel pump (da-31) same can hear oem pump prime
    Audi s3 8l 2003 silver,brembo brakes,custom front mount intercooler,forged rods,acl race bearings,3inch tip,forge 007p green spring 1 shim,5mm hubcentric spacers,pipewerx 3inch down pipe/200cell race cat,2.75 miltek back non resonated,new piston rings,n249delete,pcv venting too atmosphere,neuspeed quick shifter,uprated clutch/pressure plate...large port agu head,inline fuel pump
    work left/relentless v3 manifold/wmi/blue haldex/antilag/launch controll/custom map!!!!!
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    What faults you get with VCDS?
    Sep 2012
    West midlands
    368
    Quote Originally Posted by Scullies View Post
    1810 voltage terminal 30 too low I'm going over there now as we speak with vcds and laptop
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    Just noticed this is a double post, just bump your old post instead of a new one. Someone will answer soon.
    i think a mod will lock/delete this one
  1. A3 2.0tdi Sport will not start
    By thebears in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th June 2014, 16:25
  2. allroad 2.5 tdi will not start
    By lofty1067 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 20th September 2010, 07:49
  3. TT APX 225bhp will not start, HELP Please.
    By t955daytona in forum TT/TT-S/TT-RS Forum
    Last Post: 30th June 2010, 17:33
  4. S3 will not start
    By ash3435 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th December 2009, 21:29
  5. 2003 A4 1.8T - Car Will Not Start When It is Cold
    By laura in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st December 2004, 17:39
