Monster MotorsportChris Nott
Results 1 to 18 of 18
Like Tree5Likes
  • 3 Post By Sam_
  • 1 Post By 16Klappe
Thread: S2000 Air Filter
    Pubemammal's Avatar
    May 2013
    Braintree Essex
    373
    S2000 Air Filter
    Hi guys I have decided on fitting an OEM Honda s2000 cone filter to my AGU engine.
    Does this filter require a reducer or will it jubilee clip straight onto the MAF? Standads air box is easy to remove I assume?
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,616
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,637
    This is covered approximately every 20 minutes. At which point, Jardo piles in claiming it's the best thing since sliced bread. There's no real evidence apart from logs which vary at the best of times and the old "it feels good" placebo. It is cheap though, and paper is meant to give better filtration.
    [Dave B], voorhees and kwistof like this.
    Handling mods++. GTX30 soon-ish. Hiding parts from the mrs since 2011. Build thread
    Nov 2012
    Kent
    451
    Add Tim_Attard on Facebook
    really its jetex or the s2000 or put it another way £50 or £15 (not sure actual price) but have a look in that thread, i had to buy a reducer for mine i have an aum
    16Klappe's Avatar
    Certified S3 Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    4,899
    Visit 16Klappe's Instagram Channel
    LOL Sam. You make me piss.
    Do you know who put me onto the S2000 air filter originally? Bill. If it is good enough for Bill it is good enough for me. Even if it doesn't add any performance over a Jetex it does the same job potentially better for less than a third of the cost, so of cause it is the best thing since sliced bread.
    And as I say all the time, if my S2000 air filter wasn't up to the job I wouldn't have the most powerful K03s on the forum. As you know with a K03 it is ALL about flow.
    I have seen a couple of S2000 turbo setups, ranging from 300 to 500bhp all using this standard filter and airbox.
    You just don't like it because it isn't a brand name to out on your list of perfect mods
    Tim_Attard likes this.
    I quite often say I'm going to do things.
    Then never do them.
    Pubemammal's Avatar
    May 2013
    Braintree Essex
    373
    Quote Originally Posted by Tim_Attard View Post
    Can you point me in the right direction on where to purchase a reducer please buddy? Is it just a standard 70-80mm silicone reducer I need? Sam
    Nov 2012
    Kent
    451
    yeah thats what i used for mine, got it off ebay very good quality
    Black Silicone Hose Straight Reducer 80 70mm by Ramair - 80mm to 70mm | eBay
    got it black as i sprayed the s2000 black
    http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/187166-tims-max-power-a3.html
    Quote Originally Posted by 16Klappe View Post
    Don't listen to him Tim, You're my hero, I'm proud of you.
    Pubemammal's Avatar
    May 2013
    Braintree Essex
    373
    That's great thanks buddy Is airbox simple to remove? Is it the AGU or AUM that has the little sensor on the air box that you have to fix somewhere else?
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,899
    Agu has an ignition amplifier in the airbox, just zip tie it somewhere out the way but as far away from the engine/turbo as you can.
    Then never do them.
    Nov 2012
    Kent
    451
    i have an aum and didnt see a sensor, its so easy to remove just 4 bolts/screws 2 either side
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,899
    That's because AUM's don't have the ignition amplifier in the airbox, it is built into the coil packs. Four wires for the coil packs, not three like an AGU.
    Then never do them.
    Pubemammal's Avatar
    May 2013
    Braintree Essex
    373
    I'm guessing all you guys with a3's and s2k filters had to use the 80-70mm reducers?
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,899
    Yup, in one way or another. But the entrance to the filter is actually bigger than 80mm, more like 82/84mm. An 80mm will stretch, but it's a push.
    Then never do them.
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,527
    Was your filter oiled jardo? Mine was caked in oil!
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,899
    No oil in mine; I got my filter from GSF.
    You shouldn't need to oil a paper filter? Hmmm.
    Then never do them.
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,527
    I got mine from eurocarparts, was caked in oil when I took it out the box?
    Nov 2012
    Kent
    451
    if you get the reducer i linked you too it fits so snug does take a bit of pushing tho
    Pubemammal's Avatar
    May 2013
    Braintree Essex
    373
    Already ordered the reducer from youe link buddy thanks. Got the filter for £12.90 delivered from: http://www.carparts4less.co.uk/cp4l/...97aabab&000008
  1. Benjamins S2000 air filter mod.
    By BENJAMIN in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th March 2014, 14:10
  2. S2000 air filter mod - problems / questions
    By Squirrelofdoom in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th July 2013, 22:15
  3. New A3 Upgraded Air Filter Offer
    By garethj in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th March 2004, 15:10
  4. Air filters induction kit on S3
    By DaveCav in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th October 2003, 17:02
  5. New air filter?
    By BarryT in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th September 2003, 08:44
