Sky InsuranceChris Nott
    Oct 2011
    greater mcr
    108
    spark plug issue !!!
    I have a bam engined 8l s3 running -
    *cus code stage 1
    *3" dp + decat
    *badger 5 - 3" tip
    *forge 008 dv
    It runs sweet as a nut approx 280 bhp (apparently, according to r/r + torque obd)
    The spark plus were due a change as 1 of them had more or less fell apart at the spark/ceramic end causing a miss fire. So I ordered the colder running ngkbkr7e and gapped them to 0.7 mm.
    The car ran OK, if a little lumpy then miss fired quite bad at 3k rpm. So I promptly changed back to standard original ones, miss fire is now gone. Any ideas what the prob is with the ngks ? When I pulled them out after 5 min they all had a white powdery coating/spark/burn marks on the spark end.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,071
    White plugs are to lean fuel mate....investigate pump?
    Oct 2011
    greater mcr
    108
    As i said mate, the car ran/runs fine with standard plugs, so i cant see it being any other issue than the ngk plugs. But it was a recomended mod on here (on a remaped car) to put the colder running ngk's in and gap them to 0.7mm ! rather than buying another set of plugs id rather try n save the ngk's, even if i have to regap them again.
    Oct 2011
    greater mcr
    108
    Any help anyone ? Is is likely that gapping the ngk's back to 0.8mm will solve this ?
    mattyboy199's Avatar
    Nov 2005
    UK
    1,679
    copper plugs gapped at 0.8mm are suitable for the TFSI coils
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
  1. spark plugs
    By Danielson in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th September 2004, 17:02
  2. Spark Plugs
    By Bradley in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th September 2004, 19:23
  3. Misfire and Spark Plugs under warranty
    By DuncS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th August 2004, 10:39
  4. spark plugs....???????.....
    By smudgy57 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th July 2004, 17:33
  5. spark plugs
    By sahk in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th April 2004, 01:23
