Stuart35205
This morning I decided to simplify the pcv system so I removed all this.
Just aswell really because the breather elbow was cracked and split in two and a few other components were split. I had to dash out to tps before they closed and grab a new breather elbow £27 quid not impressed! I used some 3/4 hose I had and made a start but there isn't a great deal of space & bieng a gas fitter I've got pipe & loads of fittings so I knocked this up as it slots perfectly down by the battery & you just pop a tray ender the car to catch the muck.
I did alter it slightly to help with hoses
Then sprayed some 28mm clips and mounted to battery cover you simply unclip catch can when you want to remove battery cover.
And this is what it looks like
