JMB RetrofitsAH Fabrications
    Jan 2011
    Glasgow
    239
    S3 leaking water now loud climate control. Video attached.
    Recently the S3 has been leaking water behind the dash onto the passenger footwell. I've removed the pollen filter to find it soaked, replaced that wet again still leaking. Unsure what to do left it for a while now today on the way home after very hard rain I hear the following:
    S3 fan - YouTube
    Help would be appreciated thanks
    Jan 2011
    Glasgow
    239
    Must be someone who can help? Thanks
    Jan 2011
    Glasgow
    239
    Need help! Lol
    Sep 2005
    Derbyshire
    180
    I'll try. Have you scanned for fault codes? If so has anything come up? When you replaced the Pollen filter was it seated correctly, if it's fitted wrong they leak water into the passenger footwell!
    When removing the pollen filter, have a good feel around in there and clear out any and all debris (leaves etc).
    Jan 2011
    Glasgow
    239
    I've not scanned the car, need to get hold of a vagcom again. We found the source of the leak it was the scuttle trim was full of dirt and was allowing water to gather and run behind the pollen filter. But been left with this horrid noise when climate control is activated
  1. Climate control problem/leak.....
    By macninja in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 31st October 2006, 11:30
  2. Climate Control Problem
    By adjturbo in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th December 2003, 21:38
  3. Audi A3 Climate Control
    By ramstein666 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th October 2003, 20:18
  4. removing climate control module
    By DrX in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th September 2003, 08:30
  5. Retrofit LCD climate control
    By dandy in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th February 2003, 11:42
