Chris NottAH Fabrications
Results 1 to 11 of 11
Thread: Stage 1 remap
    Feb 2013
    21
    Stage 1 remap
    Afternoon all
    Not long had my S3 but have had new clutch done and Cambbelt is being done in the next few weeks. Car is standard other than a K+N panel filter, was wondering if I need to upgrade anything else etc for a stage 1 map?!?
    Also which n where are the best places to get this map done?! Not sure wether to get a map which you can take off if needed either, all ideas/opinions welcomed
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,634
    Badger 5 TIP would be nice! And a catch can/ PCV delete. Also make sure there's no boost leaks! And get a good stage1 map from a reputable tuner!
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,897
    Where are you Shaun ?
    Change your Diverter Valve to a Forge one.
    Feb 2013
    21
    I'm in Guildford Surrey, are catch can and PVC delete easy to do?
    when you reputable tuner are there many around?
    cheers
    Nov 2012
    Kent
    459
    Add Tim_Attard on Facebook
    for a map its really got to be r tech or badger what ever is closest, id say give it a good service plugs, oil etc, check for leaks, pcv and n249 are easily done (look in stickies), a new tip badger 5 as said or a oversized sfs standard dv should be ok but if you do want to up grade go for a forge again look in stickies
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,511
    Quote Originally Posted by voorhees View Post
    Keeping the standard DV is the 'in' thing these days Jase.
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,897
    Quote Originally Posted by jojo View Post
    So the standard spring will keep up with the remap Joe ?
    Nov 2012
    Kent
    459
    yeah should do fine, if im correct in thinking that the forge ones are not that amazing unless you get a new one as they have been revised? could be majorly wrong
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,511
    The standard plastic DV has been tested by Bill badger at over 30psi with no leaks!
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,897
    Shaun when your at least ten year old standard DV goes pop just get Joe and Tim to sort it
    For the sake of a £100 I would change it.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,511
    Aye Jase, Bill also tested a whole load of aftermarket DVs, and most of them leaked! There's vids on fb.
  1. 1.9tdi (130) sport stage 1 remap AMD
    By imported_CurryMilkShake in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st February 2007, 00:03
  2. AMD Stage 1 Remap on 2.0L
    By Mikebabs1 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th November 2005, 12:53
  3. Stage 1 Remap at AMD - My Experience
    By ritmark in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th June 2005, 14:11
  4. MPG after AMD stage 1 remap
    By jediknight in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th April 2005, 14:28
