    Jul 2011
    Very north of England
    42
    Help please, no brakes.
    Hi
    I changed my rear discs and caliper yesterday everything seemed okay. I pumped brakes as normal but didn't test drive. Today I get in the car and brakes seem fine until I tried to gently brake but there was nothing there, **** myself. Pumped again and braking hard seems to work but again when braking gently pedal goes to the floor. Any ideas?
    Taff
    A3 8l
    Mar 2013
    Blackburn, Lancashire
    17
    Hi Mate
    First bleed the two nipples on the master cylinder, DO NOT press the pedal do one at a time and just let it trickle out on its own for at least 20 minutes each, make sure you keep it topped up with brake fluid.
    next bleed the caliper furthest away from the master cylinder in the same way and the do the other three after that, do not presss the pedal just leave it trickilng out.
    This should do the trick
    Jul 2011
    42
    Cheers Barlow weather supposed to be good tomorrow will do that then.
    Audi A3 8l 2001
  1. Help Please ASN - Brake light trouble
    By sniffy_smiffy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th November 2011, 19:42
  2. Help please!! Facelift Brake lights
    By TaylorK in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th October 2011, 17:07
  3. help please - S4 BRAKES onto 2.0 TDI
    By doug.p in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 22nd September 2011, 09:21
  4. Brake Dust! Help Please????
    By Add7 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd July 2004, 00:01
  5. HELP PLEASE!!!!!!! Intermittent brake lightfailure
    By howard in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd December 2003, 23:20
