EM TuningChris Nott
    May 2013
    Glasgow, Scotland
    195
    Air Mass Meter Signal Too HIGH ???
    Hi guys,
    Just had my 2002 A3 1.8T in Glasgow Audi today to have the ignition coils recal done. I also asked them to run a diagnostic on the car as l was expriencing rough idle, hesitation in 3+4 gear at 3500 revs which in turn illumnated the tractin control light.
    Last week l had run injection cleaner through the car, cleaned the MAF and cleaned the Throttle body.
    So they only changed 1 coil as it turns out that the car had 3 aftermarket coil packs and they could not replace them.
    They did however find faults, Air mass meter signal too high and turbo/throttle connection pressure drop. I was advised by Audi that the pressure drop was prob because i had the throttle body off ??
    So my question is would this indicate a faulty MAF Sensor ?? Would the MAF sensor trigger the traction control light to come on ??
    Cheers for ay help !!
    Brendan
    BENJAMIN's Avatar
    Mar 2011
    472
    Is the car mapped? If so by who?
    '09 Lci 335d individual. M-dev stage 2, 360bhp 550ftlb. 'Undercover police edition'
    May 2013
    Glasgow, Scotland
    195
    No mate as far as i know completely standard, l only bought it 2 weeks ago !!
    May 2013
    Glasgow, Scotland
    195
    In reading through pages of forums, could this be a boost leak ?? if so is there anyway to test easily ??
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Faulty Maf brings the traction light on...
    May 2013
    Glasgow, Scotland
    195
    Hi dave, im just reading through post on here. Acually the 1 im reading you are in it !! Anyways its quite interensting as someone called Murran is saying if i was getting the pressure drop fault with the MAF reading too high then its prob a boost leak !! Its only when im pushing the car in 3,4,5 gear the tcl comes on !! Im really starting to think its a leak rather than the MAF !!
    If i go disconect the maf and run for a few miles and the tcl does not come on, then its the MAF ??
    But if its still the same under heavy load, then its a leak ???
    What you thiink?
  1. MAF signal too high. any ideas?
    By Prawn in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th October 2010, 21:23
  2. finding the right air mass meter
    By s3xy in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th July 2010, 18:49
  3. Air Mass Meter and Coolant Temp. Sensor
    By nu boy in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th April 2008, 20:29
  4. Air Mass Meter
    By in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th June 2005, 14:17
  5. Air Mass Meter
    By darrenp in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th November 2004, 12:09
