Badger5AH Fabrications
Results 1 to 15 of 15
Like Tree2Likes
  • 2 Post By Pmol66
Thread: S3 Cup Holder Retro Fit Pre-facelift
    Staffordshire
    201
    Hi people,
    Half of this is a guide and the other half is just showing you how i did it because you may find a better way than my bodge... I mean improvisation
    Feel free to input anything that will make this an easier or better job
    Here are some of the tools i used.
    -Dremel type rotary tool
    -8mm spanner
    -Straight edge
    -Screwdrivers
    -Stanley knife
    -Araldite
    This is how mine looked before. And a pic of the cupholder i'll be bodging. I mean fitting.
    Part number 1M2862531C 1M1862531C From the Seat Toledo but the Leon cupholder also fits - 1M2862531D 1M1862531D
    Other cup holders will fit doing it this way, so take your pick.
    -The face of this will need replacing as its not the right shape to fit the audi trim. Two of these blanks will be needed
    Okay....
    Starting by removing the glove box will help, giving more space later on.
    Remove the ashtray
    Remove the stereo. (My be different if you have a cage.)
    Carefully prise the trim starting from the bottom and remove.
    Pri out all four switches and unplug them.
    Undo the two screws at the top of the cage to allow you more access.
    Push both the ESP and Rear Screen heater connectors into the cage and out somewhere you can see enough wire to play with.
    At this point i was unsure of what to do with rear heated screen switch so i cut the plug off and extended the wires out the way.
    Will re locate at a later date. Unless you dont have heated seats then it can stay put.
    I think i can live without the ESP lol so its been taped up.
    Line the stereo compartment with a rag or something to catch the mess your about to create
    To get both heated seats on the right. The left one needs opening up.
    Thats quite simple as you just need to copy the hole next to it.
    Now onto the tricky side.
    The main bit that has to go is the central divider
    These bits are best removed from the bottom of the holder-
    The rest is up to you. Its just a matter of trail and error.
    If you think you have it in ok. Make sure the cupholder operates because if one of the clips on the outer casing are pushed in, it wont work. I removed one of them.
    I used a cutting disc to remove most of the plastic above and finnished off with one of the small sanding stones.
    I ended up with this mess
    *see the two peices of plastic glued on the left side of the opening. That will stop the switch from tilting (its very close to one of the clips on the cupholder though)
    When you have gutted your cage enough it should look something like this
    Make sure it operates then remove.
    Unplug the two pins that hold the face of the cup holder on and remove the face
    Put the c/h back in place and secure it some how, making sure its level.
    I used Liquid metal and Araldite as thats all i had at the time. Make sure its nice and level and let it go off before putting the other switches back in.
    Reassemble and we have nearly done.
    The two blanks now need shaving down to fit.
    This is something like what it needs look like.
    They need gutting completely to be honest.
    Keep checking them up against the c/h as you shave and eventually they should go flush with the trim.
    Choose your poison then stick them on.
    Job Done! Put the kettle on
    ...................Paul.
    Paul
    Dani_B19 and sam4191 like this.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,221
    Very good matey, proper write up. Makes me laugh though how its only you and me that post up about this or even seem bothered haha.
    So where you ended up putting the rear window switch?
    Staffordshire
    201
    Cheers dude!
    I know!! I was expecting everyone to be wowed haha.. pmsl
    We cant be the only surviving preface reprobates on here..
    Its sitting underneath my ashtray for now. Im going to get my turbo re-conned first then i might get a tt one. See if that will go somewhere...
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,221
    Ano i thought same pal.
    Whats up with the turbo? Whats the tt rear window switch like? Ive only looked at the seat ones.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,221
    Argh just seen them. Look alot better just like the seat ones. May have to buy that as well lol.
    Staffordshire
    201
    I presumed you knew mate. Will make relocating easier being round!
    I went for a plug in and to see where my oils leaking from. They told me the turbos on its last legs too :/
    But on the plus side, im loosing boost at the min. I think a re con should show some power gains i never knew i could gain
    Staffordshire
    201
    The weirdest thing happened the other day. I went through Mcdonalds drive thru and the nice lady on window two said "would you like a cup holder" i replied "no thanks".
    Then this thing popped out the dash.
    I put my coffee in it and drove off without spilling any.. It was strange lol.....
    How did you get on with your plans mate...
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,631
    I don't have heated seats, so I can put the rear screen and esp next to each other
    Staffordshire
    201
    thats good news mate. Iv give up thinking of where im going to relocate my rear window switch. Doesnt seem to be many options...
    Staffordshire
    201
    Hi mate. Hows it going...
    Did you get anywhere with your cup holder or more importantly, the relocation problem?
    -Paul-
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,221
    Oryt mate. Not yet. Ended up buying my first house and a largeport head so been a bit busy haha.
    Staffordshire
    201
    Oh fair enough mate. Same here nearly. Just settling into a new house. Time to sort the rest of this out lol..
    Im waiting for the tt esp and rear w/heater switches to arrive.
    I'll keep you posted...
    -Paul-
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,221
    Just draining int it haha. Yeah keep me updated pal.
    Staffordshire
    201
    Mentally and physically lol.
    Iv decided Dani.. Im sacrificing my ashtray. Iv gutted it and in the process of making a fibreglass casing to house the switches. Im hoping to get it sitting where the ashtray was.
    The other option is extending the piano black trim but before i start chopping that up. I'll try the safe option.
    Do you have any idea if its possible to get the piano black finnish out of a can?
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,221
    That'll be interesting.
    Not what I know of mate, with it been gloss black plastic, it'll be hard to replicate with paint.
  1. Cup Holder Retro Fit. Pre Facelift
    By Pmol66 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th May 2013, 21:25
  2. Cup Holder Retro Fit - Pre Facelift
    Last Post: 13th May 2013, 18:15
  3. Will S3 facelift lower console fit pre-facelift
    By SunnyB in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th August 2011, 16:28
  4. will 2005 s3 2.0 downpipe and cat fit pre facelift
    By garyrmills in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th August 2009, 15:40
  5. 09MY diffuser/ valance fit pre-facelift?
    By ~RS~ in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th March 2009, 02:12
