    Feb 2012
    Denmark, Copenhagen
    199
    Knocking when going into second gear
    When i go into second gear, before i let go of the clutch, a knock can sometimes be heard, unless i do it really carefully. Normal gearchange, it knocks. I can produce this sound, if i "pump" the cluctch at low speeds at 5-10 mph, in second gear. It is not that loud of a knock, but it is clearly metal hitting metal, and its driving me nuts!
    I like to go into neutral when i stop at a light that has just turned red. Then sometimes when i want to into first, it is literally impossible to go into first, like the gears wont move. Doesnt even wiggle, at all. I then go into neutral again, and then it will go into first, but only after doing a really loud knock. I am not sure if the 2 issues are connected. Driving is fine, the other gears are smooth as butter.
    Are there any known issues with the 5 speed gearboxes? Its a slightly modded 1.8T AUM @ 145.000 KM (90.000 miles)
    Feb 2012
    Denmark, Copenhagen
    199
    Update: I have been told to try and change the dogbone mount, as they like to make noises when worn. I have looked at a new one from ESC in the USA, as its actually cheaper than the OEM piece, but is supposed to be better. They dont have any data on the A3 as it was never sold in the US.
    Will the rear dogbone trannymount from a MK4 Golf GTI fit my A3 8L 1.8T?
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    Quote Originally Posted by anderswhk View Post
    yes it will
    Feb 2012
    Denmark, Copenhagen
    199
    I keep reading that after changing this i must do a "full linkage shift allignment". Is that really nescesarry, and how much work would be involved? I have acces to a lift, but are not really mech sawwy at all.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    no idea where you read that, that isnt the case when fitting a dogbone engine mount.
    however, givin your initial issue, a gear linkage alignment is probably worth doing.
    try and view the instructions on forges website for fitting a short shift, that tells you how to reset the cables. really easy job though
  1. Replies: 0
    Last Post: 13th April 2012, 09:28
  2. knocking sound when going over potholes humps
    By anilkumar in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd January 2011, 20:00
  3. Reverse gear grinds when going in..any ideas??
    By kooch_481 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th June 2009, 11:31
  4. Crunch going from 1st to second gear
    By Vron in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th February 2008, 10:28
  5. Crunch going into third gear?
    By S3K in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th April 2005, 17:36
