JMB RetrofitsSky Insurance
Results 1 to 36 of 36
Like Tree1Likes
  • 1 Post By Pmol66
Thread: Cup Holder Retro Fit. Pre Facelift
    Staffordshire
    216
    Hi people,
    This is my first thread so bear with me
    Half of this is a guide and the other half is just showing you how i did it because you may find a better way than my bodge... I mean improvisation
    Feel free to input anything that will make this an easier or better job
    Here are some of the tools i used.ImageUploadedByTapatalk1368451527.498737.jpg
    -Dremel type rotary tool
    -8mm spanner
    -Straight edge
    -Screwdrivers
    -Stanley knife
    -Araldite
    This is how mine looked before. And a pic of the cupholder i'll be bodging. I mean fitting.
    Part number 1M2862531C 1M1862531C From the Seat Toledo but the Leon cupholder also fits - 1M2862531D 1M1862531D
    -The face of this will need replacing as its not the right shape to fit the audi trim. Two of these blanks will be needed
    Okey Dokey
    Starting by removing the glove box will help, giving more space later on. 3 torx screws inside, one outside, at the bottom right corner and the rest are behind the cover you can prise off with the door open. Unplug and remove...
    Remove the ashtray with the one philips screw and unplug.
    Remove the stereo. (My be different if you have a cage.)
    Carefully prise the trim starting from the bottom and remove.
    Pri out all four switches and unplug them.
    Undo the two screws at the top of the cage to allow you more access.
    Push both the ESP and Rear Screen heater connectors into the cage and out somewhere you can see enough wire to play with.
    At this point i was unsure of what to do with rear heated screen switch so i cut the plug off and extended the wires out towards the glove box. Will need relocating if you have heated seats. If not, you should be able to get it back behind the trim.
    I think i can live without the ESP lol so its been taped up.
    Line the stereo compartment with a rag or something to catch the mess your about to create
    ImageUploadedByTapatalk1368454438.334961.jpgTo get both heated seats on the right. The left one needs opening up.ImageUploadedByTapatalk1368454539.418131.jpgThats quite simple as you just need to copy the hole next to it.
    The main bit that has to go is the central divider
    These bits are best removed from the bottom of the holder-ImageUploadedByTapatalk1368455477.867860.jpgImageUploadedByTapatalk1368455492.601496.jpg
    The rest is up to you. Its just a matter of trail and error.
    If you think you have it in ok. Make sure the cupholder operates because if one of the clips on the outer casing are pushed in, it wont work. I removed one of them.
    I used a cutting disc to remove most of the plastic above and finnished off with one of the small sanding stones.
    I ended up with this mess
    *see the two peices of plastic glued on the left side of the opening. That will stop the switch from tilting (its very close to one of the clips on the cupholder)
    When you have gutted your cage enough it should look something like thisImageUploadedByTapatalk1368456786.153543.jpg
    Make sure it operates then remove.
    Unplug the two pins that hold the face of the cup holder on and remove the face ImageUploadedByTapatalk1368456902.203284.jpg
    Put the c/h back in place and secure it some how, making sure its level.
    I used Liquid metal and Araldite as thats all i had at the time. Make sure its nice and level and let it go off before putting the other switches back in.
    Reassemble and we have nearly done.
    Im just waiting for my blanks to arrive
    Hopfully will be tomorrow..........
    Dani_B19 likes this.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Haha love matey, cant wait for tomorrows instalement. You not fitting 2 cup holders then?
    Staffordshire
    216
    Cheers I didnt mean to post this just mate if you look it up again. Theres a fresh one with the last pics on....
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Sorry mate dont follow, so you fitting one or two? Will tomorrows right up include you chosen place of choixe for the rear window button lol.
    Staffordshire
    216
    Cup Holder Retro Fit - Pre Facelift
    the pics seem to be better on this one mate.
    haha id love two cupholders. id have a glove boxfull of switches tho hehe.... what are you going to do with yours
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Haha yeah much better matey. Err not too sure, im really tempted to fit 2 and relocate the heated seats and window switch next to the handbrake area but im also thinkig about using tt heated seat switchs if theyd work.
    Staffordshire
    216
    Interesting lol. I totally dismissed that area just for the shear size of the switches. Tt ones would look better. Especially if they are seperate. The audi ones look odd separate. Have you seen anyone locate to there before.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Aknow they are chunky thas why i hope the tt ones fit the s3 relay without chopping and soldering. No mate but im hopeing to be the dirst so watch this go ****ing tits up big tym haha. Ill end up needin a new interior haha.
    Staffordshire
    216
    Hahahaha. I like it. I actually thought u wer playin with me the other day when u asked me where to put the switches. Fair play to ya... I might hold on to this other cup holder. Watch this! Pmsl...
    Do you have an armrest in yours mate?
    Staffordshire
    216
    You've got me thinking now...
    If it doesnt plug in. How would you go about it?
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Haha nar mate, was been serious.
    Yeah ive got one, have you?
    if the tt switchs dont work id look to shave the buttons down and install them someway or ova but it wont easy due to their size where as the tt ines look smaller.
    Staffordshire
    216
    No i didnt even give tt a thought to be honest untill u said. I think i might see how u get on lol....
    Staffordshire
    216
    Oh, i have got an armrest yeah.
    I cant see me having the two cup holders tbh mate. Unless you come up with somthing amazing lol. Theres space behind the cover around the steering wheel, the other side to the headlight switch. Thats where i put the hazzard switch on my a3. Those tt ones could easilly be put there. Just dont put them where your knee is like i did lol
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Haha i mean to have a look at it all today but got wrapped up
    gutting the inside and cleaning it all down lol.
    Your blank turned up yet?
    Staffordshire
    216
    Fair nuff lol.
    No they havn't come yet :/
    Staffordshire
    216
    F*** iv just fitted a 20 year old cup holder to my car haha.... Their are better ones been made since which are the same shape unit.... ImageUploadedByTapatalk1368582131.703571.jpg
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Haha never, whats that one from? Any part numbers?
    Staffordshire
    216
    It's weird because they never diagnosed me with special needs
    Yeah its the a2
    8z0862534a
    Thats the best one i can find. Just searched the bay for audi and vw ones.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Its ok mate, most of us on here are undiagnosed too lol.
    That looks alot better mate, and both sides are rounded.
    Staffordshire
    216
    Hahaa.... It does look better and yeah didnt realise its rounded! Bonus!
    Took one for the team here havnt i... Lol
    Iv got 65 quid worth of parts i dont need now haha
    For sale..... Covered in Araldite but in working order....
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Yes mate you certainly have haha. You selling all the leon and toledo cup holders now haha? Im going to buy that a2 one, was waiting until payday on friday to buythe leon one so glad i waited haha.
    Staffordshire
    216
    Hehe... Yeah the ones up on ebay now. That WAS lucky lol...
    looks like its wider too. Have u ever used one them leon ones. Good for a can, but anything like a maccies cup only sits half way down it, if u catch me drift.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Defo. No mate not used any of them, the a2 one doesnt look too deep either though and looks like it may need more trimming than the leon one as well.
    Staffordshire
    216
    Yeah, the cup wont budge but looks untidy to me... Hopfully that flap on the spring does its job. Heres what yours will be lookin like if u can stash your seat switches lol...
    Do you think it'll need more trimming. I thought it'd be the same size
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Argh cool, not sure wether to have 2 now looking at that, looks abit too much haha. Going to buy one on friday then fit that and see how it goes. Where have you reloctaed the rear window button too?
    I think it might, the casing looks to have more edges on it so may need some trimming to get it in.
    Staffordshire
    216
    Yeah they're quite beefy. I havnt yet. Im going to get a TT one, see if they can be used.. Not sure where yet. I might let u lead the way on the relocating lol.
  28. #27
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Haha well i going to have a look through rest of this week and weekend, if i fit ine cupholder ill copy uou with the heat switchs then find a location for the the rear window switch but if i fit 2 ill be movigthem all haha.
    Did the passenger seat switch need wires cuttting or did it relocate easily?
  29. #28
    Staffordshire
    216
    Got ya... Good luck hehe...
    What about modifying one of those gauge holders for the pillar. Fibre glass ect. U'd get all 3 switches in one them lol... Yeah it went over no problem mate. That bit was straight forward to be fair
  30. #29
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Thats good to know.
    Nar that wouldnt go, id want it to be sutal but still like wow if ya get me haha. Itll either be handbrake area, ashtray or around the light switch, ill see what i can knock up haha.
  31. #30
    Staffordshire
    216
    Yeah i know what u mean.
    Oh yeah! the thing iv found, now both the seat switches are on the right. If i wanted a cup holder there now, id have to re do the cage as theres a gaping hole there.
  32. #31
    Staffordshire
    216
  33. #32
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Very smart dude. So you keeping the leon cup holder then?
  34. #33
    Staffordshire
    216
    Yeah for now. Iv got some other stuff to do before i start buying more cup holders haha. My turbos on its way out :/ so when i get bored again i'll update it..
    No more spilt coffee! :D get in !! Haha
  35. #34
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Lmfao, i know that feeling mate. Make sure you post up when its all done. Going to plan it all out tomorrow and friday and order all my bits ready to attack it haha.
  36. #35
    Staffordshire
    216
    I will do. Should have it done after work tomorrow... Plan? I might try a plan next time pmsl..,
    Look forward to see your outcome mate
  37. #36
    Staffordshire
    216
    Job done my friend
    http://www.audi-sport.net/vb/showthr...03#post1874103
    I think i will get an a2 one eventually.
  1. Fitting pre-facelift S3 xenons to a pre-facelift a3 - wiring?
    By Dibdub1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th September 2012, 18:49
  2. facelift headlights fit pre facelift ??
    By ben681 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th October 2011, 19:05
  3. Will S3 facelift lower console fit pre-facelift
    By SunnyB in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th August 2011, 16:28
  4. will 2005 s3 2.0 downpipe and cat fit pre facelift
    By garyrmills in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th August 2009, 15:40
  5. 09MY diffuser/ valance fit pre-facelift?
    By ~RS~ in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th March 2009, 02:12
