Badger5JMB Retrofits
    May 2012
    38
    Dieselgeek Short shift
    Recently purchased a dieselgeek short shift, all fitted and adjusted several times etc...
    Either reverse is hard to get into with the remaining okay or 1/2/3/4 short and 5/6 very long...
    Is there a way to lock the shifter in place much like the 8P?
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,542
    Yes, was there not instructions with the shifter? You need to set the cable lengths.
    There ia a guide somewhere, in fact forge will have the guide online for their shifter kit.
    Its basically, neutral, pin on gearbox locks the shifter in place. Then in the car, gear stick is locled in place by a 5mm nail or similar, then in the bay, you unclip the cable ends where the spring is, then release and the spring clips grab the cable in the new position. Then take the locking pin out the box, and the one out the gearstick, and cycle the gears and youre done.
    May 2012
    38
    Boom!
    Thanks for the help, thank you!
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,789
    The pin location on the gearstick is kinda towards 2nd, you'll see once you have it apart. The dieselgeek setup is an awesome bit of kit. I now have a bit of play at the lever end I need to sort somehow though
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
    James333's Avatar
    Dec 2007
    227
    https://www.youtube.com/user/dieselgeekdotcom/videos
    A few of these should help, can't go through them now but i'm sure there are one or two showing exactly what to do and where
    2001 AMK S3 Custom Code stage 1, B5 TIP, Jetex filter
  1. DieselGeek short shift
    By j4jon in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th April 2008, 19:56
  2. Does anyone have a dieselgeek short shift on their S3?
    By bantam1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th November 2006, 15:47
  3. Where can I buy B&M Short Shift kit in UK for a TT
    By Rai in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th April 2003, 13:04
  4. Where 2 buy B&M Short Shift kit in UK for a TT?
    By Rai in forum TT/TT-S/TT-RS Forum
    Last Post: 28th April 2003, 12:33
  5. TT short shift for a3t ??
    By ooooaudi in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th February 2003, 15:03
