Sky InsuranceAH Fabrications
Results 1 to 7 of 7
    May 2013
    21
    traction control
    Have an issue my traction control has been kicking in on full lock, anyway traction light is permanently on now what could cause this please
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,607
    Is you steering wheel on straight? as in driving straight ahead and its straight...
    <tuffty/>
    May 2013
    21
    <tuffty/>
    Yes all fine mate abs light is screen as well
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,607
    Need to scan for fault codes... sounds like a dodgy ABS sensor and damaged ABS wiring
    <tuffty/>
    May 2013
    21
    <tuffty/>
    Yeah I'll get it fault coded did a quick search on here and something about a unit behind dash about 300 quid nearly fell over
    May 2013
    21
    could this be my haldex unit as back wheels lock up on full lock
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,607
    Quote Originally Posted by chink View Post
    Yes but it could also be triggered from a duff sensor relating to the ESP/ABS... scan first then see what comes up... haldex lock up due to dodgy controllers etc are more noticeable a low speed and doesn't have to be full lock... the fact the traction light is on too suggests another fault
    <tuffty/>
  1. Traction Control, Mechanical Vs Electronic
    By Punisher in forum Tuning
    Last Post: 27th February 2005, 11:32
  2. Traction Control
    By FactionOne in forum VCDS (formerly VAG-COM) forum
    Last Post: 26th February 2005, 19:58
  3. Part 3 - Racelogic Traction Control
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th November 2004, 17:21
  4. Traction Control
    By in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th October 2004, 01:28
  5. traction control
    By youngdriver in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th April 2004, 18:42
