AH FabricationsSky Insurance
Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By jojo
Thread: Track rod end fitting guide?
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Anyone got a guide for fitting new track rod ends? Think im going to replace mine before i get the car aligned as ive had 4 years and theyve never been done so thought may as well.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,499
    Wow, it's pretty much the same for most modern cars, kinds of speak for itself once you take your wheel off and have a look! The only thing you need to worry about is wether it's seized or not?
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,634
    If its seized then heat it!
    Take off wheel. I turn it until the track rod ball joint is at neutral position.
    Loosen the bottom nut but keep it nip tight. Then loosen nut on the track rod. Once that nut is undone then take the rod end off the hub and unscrew. I normally mark the rod end and nut and count how many turns it takes to unscrew the rod end off as it keeps your alignment semi straighT. You'll need alignment though.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Never ever done it before jo believe it or not and forgot to look last time wheel was off lol. So the ends just simply unscrew off and new on. Fair dos, thanks also gops.
    Also i asked jojo as in your thread their was a special tool needed?
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,499
    You need a special tool, or a rather large spanner to undo the track rod from the rack, track rod end is a piece of cake, even for a 'have a goer' like me.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Argh so you chnaged the rod and not the end.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Also is topran a good make to use or should i pay 3 times more and buy the lemforder ones?
    Oct 2012
    70
    Lemforder's good stuff. They're not much money if you shop around either. I've used some topran bits in the past and have been disappointed.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,499
    I changed both, stupid not to change the end if its coming off anyways!
    I got a lemforder one on mine.
    Dani_B19 likes this.
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,782
    I changed both recently (well, a garage did as they were rebuilding shocks etc so got them to put them on) and the rods themselves as the inner joint can wear. I used Meyle but I've heard Moog are also good. Lemforder are mega money.
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    Have a decent 7mm hex key ready for the hub end. If it's rounded off then have a grinder handy!
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
  1. Track Rod end seized
    By JohnboyC in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th April 2010, 21:52
  2. track rod ends
    By vw754 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th May 2009, 23:26
  3. Replies: 0
    Last Post: 28th January 2009, 21:04
  4. S3 - failed MOT on track rod end
    By bpascua in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th November 2007, 12:37
  5. Track rod end - easy to change??
    By CraigM in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th June 2005, 01:28
