Volks AutosMonster Motorsport
Results 1 to 12 of 12
Like Tree2Likes
  • 1 Post By s3dave
  • 1 Post By Pubemammal
Thread: A3 Front wiper relay location
    Pubemammal's Avatar
    May 2013
    Braintree Essex
    376
    Hi guys, anyone know where the wiper relay is located? Can't find any diagrams on this. Thanks
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    14,336
    ​Im pretty sure it is below the steering wheel. The guys will correct me if i am wrong. x
    Smaller (Local) Events
    Audi-Sport.net online magazine.
    To find Audi-Sport-Net members with VCDS check out the MAP.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    Not an a3 petrol but will be similar this is with the lower cover removed under the steering wheel as Sandra said..
    http://www.myturbodiesel.com/images/...elay-panel.jpg
    Sandra likes this.
    Pubemammal's Avatar
    May 2013
    Braintree Essex
    376
    Perfect thankyou very much
    Pubemammal's Avatar
    May 2013
    Braintree Essex
    376
    OK so removed the wiper relay... However it was still clicking when wipers were moving is this a sign that the relay may not be at fault after all?
    Also the metal clips to hold the dash panel under steering wheel... Are these just push fit because I can't seem to get them clipped back in!?
    Pubemammal's Avatar
    May 2013
    Braintree Essex
    376
    Relay
    Pubemammal's Avatar
    May 2013
    Braintree Essex
    376
    Anybody have any idea?
    Oct 2012
    56
    What problem were you getting to make you want to change the relay- intermittent wipe not working properly? Worth getting another one from a breakers yard to try it. I did when mine went on a Golf Mk4 TDI and got two of the relays for a fiver! Several models use the 377 wiper relay so shouldn't be hard to get one. Clips are push fit - just a bit of a knack to it.
    Pubemammal's Avatar
    May 2013
    Braintree Essex
    376
    Quote Originally Posted by A3_130 View Post
    Sorry forgot I posted the original problem on a different thread :o
    The problem is that the wipers do not turn off even with stalk in the off position, they stay on intermittent, wiping the windscreen every 20 seconds or so.
    Oct 2012
    56
    Maybe not the relay then... clicking sounds like the relay is probably working. How about a switch maybe? Looks like a bloke on this thread had a similar problem:
    http://forums.tdiclub.com/showthread.php?t=274078
    Pubemammal's Avatar
    May 2013
    Braintree Essex
    376
    Oh bugger! Really thought it would be as simple as changing the relay. No idea how to get to the switch! Looks like more forum trawling for me
    Pubemammal's Avatar
    May 2013
    Braintree Essex
    376
    Changed the relay today... Wipers fixed! Thank god for that. Thanks for all your help
  1. 2000 A6 2.4Q Slow Front Wipers
    By Drmatrix in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 15th August 2006, 20:49
  2. Front Wipers
    By noodle in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th January 2005, 15:27
  3. Changing Wiper Relay Switch anyone?
    By TDI in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th January 2005, 08:19
  4. Front wipers - help!
    By S3_MCD in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th June 2004, 17:20
  5. Glovebox Removal , Relay Locating
    By mrg in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th February 2004, 18:40
