Monster MotorsportEM Tuning
    Jun 2012
    Redhill Surrey
    635
    Add Grale1 on Facebook
    Had to replace the central locking pump today
    As title says, my central locking pump packed up a few weeks back so after putting it off through not having the time really to do it or justify buying a new unit and getting the key code etc, so whilst I was working away from home last week eBay became a good friend lol and found a unit where the guy had a water leak and fried the electrics to his, so took a chance as it was only £10 inc postage, came home last nit and this morning the unit arrived.
    had a spare hour late this afternoon so thought I'd give it ago.
    Pleased to say what I done has worked
    ( new unit )
    image.jpg Broken unit inside, ( old one )
    image.jpg New unit
    image.jpg Cut the wires from the motor to the board, had to do a temp fix so twisted the wires together and then used insulating tape.
    put it all back together tried it and it worked perfectly so very happy now.
    I will be getting a soldering iron to do a better job of the joining of the wires and use some of the rubber you can get that shrinks when you heat it up to protect it.
    Must say I'm very happy with this repair and all for just £10.
    Si
    A3 1.8t AGU, fk ak street coilovers, silicone tip, silicone turbo outlet pipe, forge 007p ( yellow spring ), 80mm jetex cone filter, 3" cold air feed, 3" downpipe and de cat, R-tech stage1 map 187bhp- 227ft
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,788
    Nice work! I'd try and get the heatshrink that has adhesive in to help keep the joint in one piece. Not that soldering comes apart but everything helps.
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
    Jun 2012
    Redhill Surrey
    635
    Yes heat shrink that's what I was meaning lol, I prob would still solder them as well. But must say that I'm happy that it all working again.
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,788
    I wasn't suggesting you didn't solder but just the heatshrink with adhesive gives added strength to the join that's all. It doesn't make a huge difference though.
    Wingnut Express's Avatar
    Audi sponsored by Mastercard
    Feb 2008
    Surrey
    125
    Hi Guys
    My pump is throwing up a fault codes which states 'likely to be leaking' and has been for some time so I need to change it out, but do you happen to have the part number from the unit you removed to help streamline my search for a replacement.
    No probs if not, Cheers
    Ian
    Worried that one day I may have to buy something sensible, but until then!
  1. Audi s3 central locking pump??? IS IT THE SAME AS A3??
    By Jimmy Parko in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th June 2010, 22:34
  2. where is the central locking pump
    By Boggle in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th May 2010, 12:30
  3. a4 central locking pump faulty
    By Mike B in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th April 2010, 17:07
  4. Wiring diagram for 1997 A4 Central Locking Pump?
    By clfletch in forum General Technical / How To
    Last Post: 4th April 2007, 21:27
  5. Central Locking Pump - Shattered Impeller - Audi A4
    By OOBlinkOO in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th November 2006, 23:44
