AH FabricationsChris Nott
Results 1 to 10 of 10
    russwuss's Avatar
    Feb 2013
    360
    internal diameter of DV hose?
    Hi All,
    My DV hose had a leak when I first thought the car at the end (engine side) which I cut down and refitted - this worked fine with the standard TIP - however now I have the aftermarket TIP fitted it's not long enough and pulling the TIP up causing it to bend at the turbo side.
    Does anyone know the internal diameter of the hose so I can pick some up from a motor factors place, or is it a special reforced hose?
    Thanks in advance!
    Adam
    Sep 2012
    West midlands
    368
    Quote Originally Posted by russwuss View Post
    Hi All,
    Thanks in advance!
    Adam
    same problem here 19mm won't be far off
    Audi s3 8l 2003 silver,brembo brakes,custom front mount intercooler,forged rods,acl race bearings,3inch tip,forge 007p green spring 1 shim,5mm hubcentric spacers,pipewerx 3inch down pipe/200cell race cat,2.75 miltek back non resonated,new piston rings,n249delete,pcv venting too atmosphere,neuspeed quick shifter,uprated clutch/pressure plate...large port agu head,inline fuel pump
    work left/relentless v3 manifold/wmi/blue haldex/antilag/launch controll/custom map!!!!!
    russwuss's Avatar
    Feb 2013
    360
    Quote Originally Posted by darren t View Post
    thanks! you reckon this one will be ok then? just standard radiator hose
    Autobar Rubber Heater Hose 19mm
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,040
    Normal Dv size is 25mm id iirc, you may be thinking of the breather size which is 19mm id
    Power & Torque 335bhp 285ftlb
    0-60 4.64 1/4 mile 13.02
    My GTX3071r Build Thread
    http://www.audi-sport.net/vb/a3-s3-f...ld-thread.html
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,021
    Sep 2012
    West midlands
    368
    Quote Originally Posted by StaceyS3 View Post
    was indeed lol sorry!
    russwuss's Avatar
    Feb 2013
    360
    Thanks for all the replies guys, ill order the forge kit.. Wouldn't hurt to change the N75 hose either!
    Sep 2012
    West midlands
    368
    the forge kit still dosent reach!!! You will have too extend the dv pipe still too stop from bending turbo tip !!
    Sep 2012
    West midlands
    368
    dv relocation kit might be best option atleast you get a new throttle body hose
    russwuss's Avatar
    Feb 2013
    360
    Thanks Darren! Ill have to wait a bit for this.. Clutch is going so that takes priority!
  1. What is the internal diameter of an S3 dump valve hose?
    By Reevesy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th July 2012, 18:21
  2. S3 Rad Hose Internal Diameter ?
    By sideways steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th June 2012, 17:58
  3. pd130 hose from turbo diameter
    By andrew-247 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th June 2012, 12:53
  4. internal diameter of the top rad hose v6 2.5tdi
    By scrag in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd February 2012, 19:44
  5. Boost hose clamp diameter ?
    By Bradderz_1988 in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th July 2011, 22:25
