AH FabricationsBadger5
Results 1 to 11 of 11
    scotty_24's Avatar
    Feb 2011
    Newcastle upon Tyne
    198
    3rd gear logs look ok? Feels down on power
    Done tonight 3rd gear 2k - redline
    Just recently fitted a 3 inch downpipe and sports cat
    REVO Stage 2, Eibach anti roll bar kit, forge 007p diverter valve (yellow spring), Badger5 turbo intake pipe with Jetex filter and Neuspeed heat shield, Forge upper bost hoses, N75, DV and Cam breather hoses, XS Power 3" downpipe 200cell cat and 3" cat back system, Apex 30mm springs, N249 bypass, Oil catch can and PVC delete, Front Mount Intercooler............
    BENJAMIN's Avatar
    Mar 2011
    472
    Knock correction a touch high, but good maf no's there. Log block 115 and 031 presuming your cars a facelift ?
    '09 Lci 335d individual. M-dev stage 2, 360bhp 550ftlb. 'Undercover police edition'
    scotty_24's Avatar
    Feb 2011
    Newcastle upon Tyne
    198
    Yes its a 51 plate AMK.
    Yeah I thought that, what causes knock correction?
    Ive has the intercooler pipe off when fitting the downpipe and there was no excess oil.
    I always use Shell V Power.
    scotty_24's Avatar
    Feb 2011
    Newcastle upon Tyne
    198
    And 217g/s of air flow is pretty awesome for a stage 1 I presume?
    RIP S3dave
    May 2004
    nr Glos
    7,185
    good airflow. must be the awesome TIP on it
    271bhp approximation level
    block 115/118 shows boosts
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    scotty_24's Avatar
    Feb 2011
    Newcastle upon Tyne
    198
    Ah I dont think I can log those Bill as I only have the lite version
    Yeah by the 0.8 conversion it works out 271bhp, yet the car was rolling roaded at only 240bhp a few months ago, yet with 275flb of torque.
    Since the rolling road ive fitted the downpipe, and its getting rolling roaded again on 1st june at the same place as last time, so I hope to see some gains!
    The thing thats bothering me is that Im getting all this airflow and have done all the right mods so far, but up against a frields remapped megane 225, the megane pulls away!
    Mar 2013
    155
    TOO MUCH IGNITION TIMING ADVANCE!!!!!!!
    The ECU doesn't like this - and doesn't want your engine to explode - so it pulls timing back (minus 7.5deg i see lol) to protect it!
    What was the temperature outside? You may have less correction on cold day. A few degrees correction in high temperature is good, if not you'll get high EGT ;-)
    Search google KFZWOP/KFZWOP2/KFZWOPL/KFZWOPL2KFZW/KFZW2/KFZWLB1/KFZWLB2
    Mar 2013
    155
    Oh its older chassis - you will have less Ignition areas i'm sure..
    AMK - hmmm 210hp standard i think?
    KFZWOP/KFZWOP2/KFZW/KFZW2/KFZWWLNM/KR***/KRLVFN/KFDZK/KFSWKFZK
    But whatever. Pull timing back very slightly if you have SPS or something then log again - Throttle will feel less 'stiff' when it is better. Pedal 'feel' will be firmer with timing like this
    RIP S3dave
    May 2004
    nr Glos
    7,185
    Quote Originally Posted by scotty_24 View Post
    high airflow without power to correspond to it usually leads me to suggest leaks... injested the air for the power but did'nt make the power.. Where did it go? Escape? over reading maf (it can happen)
    and of course dyno lottery
    DD rollers are'nt my personal fave
    what quality fuel in it?
    www.badger5.biz
    bill@badger5.co.uk
    scotty_24's Avatar
    Feb 2011
    Newcastle upon Tyne
    198
    It always gets v Power Bill so it shouldn't be fuel.
    i guess it's just the dyno lottery, we shall see when it gets dynod there again next month.
    Are there any usual suspects I can check that could affect the timing pull?
    I think on pay day I may invest in replacing all of the pipes under the inlet to set my mind at rest about leaks. I've had a quick look and there are a few that are oily, so there must be some leaking somewhere !
    RIP S3dave
    May 2004
    nr Glos
    7,185
    oily pipes = leak somewhere there, Smoke test will reveal
    www.badger5.biz
    bill@badger5.co.uk
  1. 3rd Gear logs for Chaz20vt - Limp Mode
    By Alex C in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th October 2012, 16:07
  2. First 3rd gear logs, don't look right.
    By jitvv in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th August 2012, 14:24
  3. 3rd gear log (readable this time) lol
    By sandwich1987 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th March 2012, 17:05
  4. 3rd gear log.
    Last Post: 9th March 2012, 14:58
  5. 3rd gear logs
    By millermk1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd February 2012, 10:45
