AH FabricationsChris Nott
Results 1 to 8 of 8
    Oct 2012
    birmingham
    197
    fault codes help needed
    first one p1426
    second one p0103
    any help please
    Lewis583's Avatar
    Mar 2010
    836
    Always check here first >>>>Link
    Quote Originally Posted by P1426
    17834/P1426/005158 - EVAP Purge Valve (N80): Open Circuit
    Possible Symptoms
    • Malfunction Indicator Ligh (MIL) active
    Possible Causes
    • EVAP Purge Valve (N80) faulty
    • Wiring/Connectors from/to EVAP Purge Valve (N80) faulty
    • Fuel Pump Relay (J17) faulty
    Possible Solutions
    • Check EVAP Purge Valve (N80)
    • Check Wiring/Connectors from/to EVAP Purge Valve (N80)
    • Check Fuel Pump Relay (J17)
    Quote Originally Posted by P0103
    16487/P0103/000259 - Mass Air Flow (MAF) (G70): Signal too High
    Possible Symptoms
    • Probably no serious malfunctions
    • Loss of power
    Possible Causes
    • Wiring and/or connections (short circuit?)
    • Mass Air Flow (MAF) (G70) defective
    Possible Solutions
    • Check wiring and connections
    • Check / Replace Mass Air Flow (MAF) (G70)
    Check continuity of the EVAP solenoid, if that's okay then you need to check that there is a feed to the solenoid. Also check whether there are any breaks in the wiring to the solenoid.
    The MAF code will require a logging session to asses how much air the engine is ingesting/thinks it's ingesting.
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    Jun 2011
    Great Melton Norfolk
    1,340
    Oct 2012
    birmingham
    197
    but i have replaced the maf for a new bosch one
    Jun 2011
    1,340
    did you delete the previous codes? and re scan again?
    Lewis583's Avatar
    Mar 2010
    836
    That doesn't mean it's any good though. New parts can be faulty too. Logging/diagnosing is required as just replacing parts willy nilly can get expensive.
    If you are adamant the new MAF is good, then you need to start tracing back wiring checking for breaks, high resistance at plugs etc
    Full VCDS
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,071
    Agreed with Lewis, heard a lot of people taking MAFs back because they are faulty..
    Oct 2012
    birmingham
    197
    will get it exchanged tommorow and fault codes were deleted last time
  1. Got few fault codes, help needed please as new to VCDS
    By JMB-S3 in forum VCDS (formerly VAG-COM) forum
    Last Post: 3rd December 2012, 01:31
  2. Fault code help needed 2000 S3
    By fitzdog88 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th April 2012, 22:17
  3. Fault code help needed plz!!!
    By shaz-raul in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 31st January 2010, 17:41
  4. BOSE Coding - Help Needed!!
    By JamS3 in forum In-Car Entertainment
    Last Post: 8th September 2006, 14:12
  5. misfiring fault, tech help needed - have vagcom fault codes
    By shufti in forum General Technical / How To
    Last Post: 16th June 2006, 22:14
