Chris NottEM Tuning
    Apr 2013
    9
    Vacuum hose to fuel regualtor
    hi all, the fuel regualtor vacuum pipe has fared and spilt on my S3, does any one know the correct size in mm I need ? Is it 3mm/3.5mm/4mm ? I've tryed 2 measure it but can not be sure, I've seen some silicone pipe on eBay but id like to buy the right size. Thank all.
    Mar 2013
    Chelmsford , Essex .
    198
    i used 4mm and works a treat
    buy extra and do the DV vacuum line while your there .
    baz
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    3mm on the FPR
    <tuffty/>
    justarn's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    587
    do all the small stuff under the mani too if you aint already, all that ****e braided stuff mine fell to bits when i took it off!
    1999 apy s3, black & blue interior,dare bbs lm's, s2000 filter, relentless v3 manifold, relentless downpipe and sports cat, scorpion cat back system, stock dump valve, badger 5 v3 tip, bam rocker cover and push in coilpacks, toyosports fmic, amd stage 2+ remap 280.3bhp 263.9 lb/ft.
    Apr 2013
    9
    Quote Originally Posted by justarn View Post
    HI m8 thanks for replay, is the braided stuff under the manifold 3mm aswell ? Thanks.
  1. air/vacuum hoses
    By dribz-s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th March 2009, 16:55
  2. Vacuum Hose undernearth throttle body
    By S3mad in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th August 2008, 19:39
  3. Charcoal Filter - Broken vacuum hose
    By nershen in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th May 2007, 20:13
  4. Split vacuum hose - part number required
    By prel2000 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st May 2007, 08:50
  5. Where to buy Vacuum hose
    By awmw in forum Diesel forum
    Last Post: 23rd February 2007, 13:46
