JMB RetrofitsAH Fabrications
    Oct 2012
    140
    Who has a evil bay 3" decat/dp
    Who has the above on their 1.8t? In particular, who has one with a welded in 200cel sport cat?
    Had to change the exhaust centre pipe yesterday as it was shot. Replaced with the TDI centre, well eventually did. Had to break open a fresh grinder disc.
    It revealed the OE DP flexi is shot.
    So, performance wise did it make a difference?
    Noise wise was it louder? ( running OE rear box).
    Ideally I would not want to run a cat, but I can't be arsed to swop it back twice a year. So the magnaflow weld in cats look a good shout. Any experiences?
    And any negatives?
    Cheers gents
    16Klappe's Avatar
    Certified S3 Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,016
    Visit 16Klappe's Instagram Channel
    S3/A3? A3 I am presuming by the TDI centre section comment.
    The one for the A3 is epic, the one for the S3 is extortionately priced.
    Sack the cat off, just man up and swap it. There are great gains to be had.
    I ran a downpipe and decat for three years on a stock exhaust, it sounded alright. A little bit raspier.
    I quite often say I'm going to do things.
    Then never do them.
    Oct 2012
    140
    AGU. making 185/220 from 15psi. K03 snail.
    Thst was before I started using vpower.
    For £100 they are ridiculous value.
    Id the OE cat actually that restriction? More the DP?
    Nov 2012
    Kent
    459
    Add Tim_Attard on Facebook
    im also wondering this between decat and sports cat, as its £100 more but how much would the garage charge to swap it over each time? or is it a DIY jobby?
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    5,016
    OE cat is a mahoosive restriction, certainly needs to go.
    With the downpipe and decat mapped in properly there is a much smoother delivery and quicker spool up. The car is free'er to rev and has less of the "cliff" of power loss top end.
    Then never do them.
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,254
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    I'm currently running a 3" DP and 200cel sports cat on my S3. Didn't fit any of it myself and my MOT was literally a week around the corner and obviously you need a cat for emissions testing etc.
    Can't prove that there was any extra performance by just bolting it all on as I didn't have it RR before and after - but there was definitely a noise increase from the front of the car and I have a standard system from cat back.
    From what I've read and seen - the standard DP and cat are very restrictive on the A3/S3, so the 3" DP and sport cat is a great mod to get more bhp - exactly how much I'm unsure.
    Just want to add though- it is definitely worth having a sports cat handy if you go and de-cat your car......because if VOSA/police check your vehicle over and find you don't have a cat...then they could ask for you to get your car re MOTd and show them proof. If you have a full 3" system from turbo back for example....you may be in a bit of a sticky situation with fitting the cat and getting it delivered in time- as you would have a lot of trouble fitting the OE one back in there.
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
  1. Quarter Mile Times.. who has slips in a S3?
    By in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th October 2004, 19:12
  2. Had Your Car Stolen? Or Know someone who has?
    By BigDawg in forum General Chat
    Last Post: 7th July 2004, 17:21
  3. Who has the highest BHp in the land?
    By SonicDeathmonkey in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th May 2004, 20:30
  4. Had Your Car Stolen? Or Know someone who has?
    By BigDawg in forum Volkswagen and other VAG
    Last Post: 12th April 2004, 21:22
  5. Who has the most mileage on an APR'd car?
    By lewy in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th July 2003, 10:24
