Volks AutosChris Nott
    Stuart35205's Avatar
    Apr 2013
    Telford
    108
    ECS Shallow sump kit
    I have the above fitted and would like some advice , because there is no place for the oil sensor on this kit it keeps the engine management light on , quite soft realy as I should have been designed with this in mind , I have heard you can have the oil sensor mapped out of the ecu? Or could I solder something between the wires like you do on the wiring for sai removal , any ideas or help would be appreciated.
    cheers stuart
    2000 A3 1.8t sport AUM
    18 BBS LM , coilovers , strut brace , poly bushed f/end , S3 front discs , S3 rear lights , wrapped roof , face lift front lights , Forge tip , cone filter & heat shield , forge 007 DV , DV relocation kit , n249 bypass , n112 removal, SAI removal , scorpion back box , ECS shallow sump , ECS single mass clutch conversion.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Its the sump from a 2ltr beetle... tbh its not that shallow and personally can't see the point... if you are smashing sumps then your car is too low... better off welding a couple of plates to the bottom like the baffled sumps have..
    This sump has been discussed before...
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Apr 2013
    Telford
    108
    It came fitted to the car tuffty , all I know is it was the kit from awsome gti judging by the receipt , It looks pretty flat to me but never seeing an original it's not my place to say , we have some pretty aggressive speed bumps by us aswell! It's realy just the sensor is like some idea what to do with . I can't see the point I'mn buying another sump and then a riser kit for the engine but maybe a last resort.
    regards Stuart
  1. Another hole in the sump - Shallow sump option or engine risers?
    By Wingnut Express in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st February 2013, 10:28
  2. Replies: 10
    Last Post: 21st June 2011, 18:17
  3. Baffled sump kit/ DIY Baffled sump
    By Rob_B in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th May 2011, 14:29
  4. Awesome gti's shallow sump kit
    By TOM.S in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th May 2011, 22:16
  5. ECS Adjustable Camber kit.
    By jojo in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th March 2007, 02:03
