JMB RetrofitsVolks Autos
Results 1 to 33 of 33
Like Tree5Likes
  • 1 Post By Vex182
  • 2 Post By 16Klappe
  • 1 Post By JUS3IN
  • 1 Post By superkarl
Thread: 202bhp ..... Not a chance!!
    Stuart35205's Avatar
    Apr 2013
    Telford
    108
    I recently bought my a3 2000 8l 1.8t , i was under the impression it was 202bhp it has had a remap by rtec I believe but my mate has a cupra which is 180 standard and its no quicker than that!
    As far as I can make out its only got induction kit , forge tip , Dv relocation kit& forge recirculating dv , exhaust wise just a scorpion bk box .
    Any thoughts pls any ideas on upgrades to make a positive difference .
    cheers
    stuart
    Sep 2005
    Derbyshire
    180
    It won't be much quicker than a standard car, to see a real difference in speed / performance (for the same weight) you'd need at least 40bhp difference between the cars.
    Check for boost leaks first and foremost and replace all the crap vac hoses that come with the 1.8t engine.
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    875
    Add Vex182 on Facebook
    Best bet is get it on a rolling road and find out!
    kwistof likes this.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Apr 2013
    Telford
    108
    Cheers for the reply , I have looked at the stickies and I'm definatly going to do the n249 removal & a couple of other bits including fitting a catch can.
    cheers stuart
    16Klappe's Avatar
    Certified S3 Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,019
    Visit 16Klappe's Instagram Channel
    Yeah, fix it.
    Niki won't map **** cars, so if it has got an R Tech map on it then I can assure you that at one point it was 202bhp and would have been a good car.
    A standard Cupra 180 is a very different drive to even a remapped K03, the mapped car will have much more torque, much more punch and a noticeable difference in power. If it isn't quicker than your mates Cupra, it's broken.
    Check for boost leaks, check for faulty MAF sensor, check for weak actuator, generally have the car fully checked over. If you don't feel up to it yourself pay a specialist.
    I quite often say I'm going to do things.
    Then never do them.
    Apr 2013
    Telford
    108
    Before I rolling road it i was going to do a decat pipe ( I have the aum so I think it's got 2 lambda sensors) and the upgrade middle pipe
    Apr 2013
    Telford
    108
    It wasn't any quicker at all it just about kept up , embarrassing realy ! I heard realy good things about rtec so I doubt it's there fault it is probably the motor at fault , would I be right in saying its got a k03s? I'm not too clued up with playing with turbos /actuators so I probably would mess!
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    5,019
    Yup it should be a K03s (unless it has been changed) and it should also have more than 202bhp given its spec.
    Then never do them.
    Apr 2013
    Telford
    108
    Ps car has no fault codes if that helps?
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    5,019
    Quote Originally Posted by Stuart35205 View Post
    9x out of 10 they won't.
    Unplug the MAF and take it for a drive.
    Then never do them.
    Apr 2013
    Telford
    108
    I'm guessing if its faulty it won't make any difference? Out of curiosity how would you check for a lazy actuator ? Cheers
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    5,019
    Connect a pump to the pipe which goes to the top of the N75 valve and apply pressure to it.
    Pull the actuator open by hand and see how much resistance there is, it should open with a little effort but not be slack.
    It's worth adjusting the pre-load on the actuator too, a lot of cars have been ****ed about with by now. Slacken the actuator locking nuts right off and using your finger to gently press the actuator closed spin the outside nut up to the actuator arm, then mark one face of the nut with tipex and give it three complete turns. Lock it off with the inside nut and job's a good'un. (for a working actuator)
    s33nyboy12 and Stuart35205 like this.
    Then never do them.
    Apr 2013
    Telford
    108
    Cheers for all the advice I will have a butchers 2moz & see If I can work anything out. Regards the maf was I close expecting it to make no difference if its shot? Cheers stuart
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    5,019
    Not really, the MAF can be cleaned but more often than not it will do more damage than good.
    Just leave it in place and unplug the sensor, go for a drive. Your ESP light will be on to signal the disconnected MAF, and you may need to clear fault codes when you reconnect but often it doesn't store.
    Then never do them.
    s33nyboy12's Avatar
    May 2012
    East midlands
    1,368
    Jaardo has given some good, genuine advice there........
    They can easily make 202bhp,,, v power or standard Ron fuel??? If mapped at r tech need v power really.
    Sean
    Current: 2013 Audi A3 2.0 tdi s line 8V in black SD nav+ extras, E46 BMW M3, 1971 Volvo p1800, 2014 Ford transit sport 155ps ;-)
    Previous : Focus st 225 stage 1 (265 bhp and too much torque), 2002 audi s3 bam engine completely OEM, 2001 Audi a3 1.8 TQS 221bhp and about 20 other cars, majority civics ek4/ek9 and Bmw / Audi soot chucker's!
    Apr 2013
    Telford
    108
    Cheers will post any findings 2 moz regards stuart
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,254
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Definitely needs to be RR before you start chasing BHP that your not sure you've lost surely?
    I mean just because your not gaping your mates 180bhp Leon and leaving him in the dust with your extra 22bhp, doesn't necessarily mean your cars not running properly and it's not 202bhp.
    Jardo has given some very sound advice- but personally I'd get it some 99 RON in her and chuck it on the dyno and see if any horses have been lost. There's no point in trying to fix stuff if it's not even broken?
    I know the COV group have a RR day at AMD Essex either this week or next- but not sure on your location.
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    Apr 2013
    Telford
    108
    Cheers all for the advice, so this morning I did the n249 by pass and sai removal , I'm amazed with how much junk was removed! I have a couple of questions , firstly it's possible the n112 valve was not electrically connected coz I never had to unplug it! What diference would that make? Secondly with the sai removal thread it tells you to solder in two resistors one for sai connection & the other is the n112 connection I am just about to do that but do I still leave the n249 electrically connected? Last question is on th inlet manifold there are two vacume connections on I have just replaced the pipe to the fuel pressure regulator and left connected in the same manner and the other one next to it I have connected to the dv is this correct or does it need to go through a non return valve ? Just a bit of confusion on my part swapping between threads! Engine bay looks loads better & very impressed with the threads I have used for advice on this . Regards stuart
    Apr 2013
    Telford
    108
    Well all done & just taken out for a drive and I can happily say it feels loads better , might just be me but as you power on the car even sounds like it roars and it feels pretty quick so I think when I get chance a rolling road is in order to check everything over as advised earlier .
    cheers Stuart
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    If its been mapped by rtec you would have the print out, who would throw that away after spending the money? What boost is it making?
    1999 apy s3, n249 delete, sai and n112 delete. bbs lm reps, s2000 filter, relentless v3 manifold, relentless downpipe and sports cat, scorpion cat back system, badger 5 v3 tip, bam rocker cover, push in coilpacks, toyosports fmic, amd remapped to 280.3 bhp and 263.9 lb/ft.
    Apr 2013
    Telford
    108
    I have got the print out but it doesn't realy make any sense when I first looked at it, I will dig it out again & have a look, cheers Stuart
    2000 A3 1.8t sport AUM
    18 BBS LM , coilovers , strut brace , poly bushed f/end , S3 front discs , S3 rear lights , wrapped roof , face lift front lights , Forge tip , cone filter & heat shield , forge 007 DV , DV relocation kit , n249 bypass , n112 removal, SAI removal , scorpion back box , ECS shallow sump , ECS single mass clutch conversion.
    Apr 2013
    Telford
    108
    Apr 2013
    Telford
    108
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    those curves are before and after... 130bhp and 120 torques before 180bhp and 180 torques after so not 202 no sorry dude, unless the previous owner fixed the problems. problems are on the next sheet, boost leak around the catch can mod? and an after market cat/decat restricting flow!?
    Feb 2013
    262
    Maybe not totally relevant but I had a golf mk4 gti with the aum engine so it had a ko3s, it was mapped by r-tec to 221bhp and was massively quicker than a standard car, as a comparison it was almost exactly the same as a standard astra vxr on acceleration, a vxr would easily beat a Cupra 1.8T 180.
    Now I know the gti is 150bhp as standard so not the same but once mapped should give a similar figure to the OPs mapped car
    Audi S3 : revo stage 2+
    hughjass's Avatar
    Is there somefin in my teef?
    Dec 2012
    staffordshire
    289
    Bottom 2lines that cross @ 5000rpm look to me as standard bhp/torque and top 2 is re-map results bhp and torque.
    180 bhp ;-(
  28. #27
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,868
    I read it as 202,I guess we need nikki to confirm but either way things change/parts degrade and the car isn't going to stay that forever.
    just saying
  29. #28
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    Quote Originally Posted by justarn View Post
    sorry correction, 220 of torque and 180 bhp after map... not bad torque!-) my mates 1.8t is a stage 2 amd with 3inch downpipe decat and stainless running 208bhp and 245 torques
  30. #29
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    correction again your right, those figure i gave are at the wheels, zoomed in at the top! so your actual every day figure i.e at the flywheel is 202bhp and 152 lbs ft of torque they are very good figures mate and that should smash your mates cupra unless the cupra's been played with aswell?? check for boost leaks and replace all the vac lines with a lenghts of cheap samco off ebay if your on a budget... check all your n75 pipes and from the turbo through the intercooler and to the inlet aswell. not worth changing anything else until you've checked all this is good and mayybe fitted new clips!? good luck
  31. #30
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    5,019
    So it's also 180 and 180 then...
    That graph isn't healthy, that graph looks like a K03 graph, not a K03s! Even a standard car should map to 215bhp in good running order.
    What Niki has put there is that there is a boost leak and removing the PCV system will help to rectify the fault. Niki won't map "leaky" cars anymore, because they are always turd and not worth putting his name to for obvious reasons.
    And justarn; those figures are NOT good.
    Then never do them.
  32. #31
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    i actually read the 180 torque figure off of the bhp numbers then corrected myself... smart arse! nice job with your car btw!-) i know rtec do a custom map so i guess it should be higher than a generic map, im pretty new to the 1.8t scene to be honest... in the end i read it right no?
    16Klappe likes this.
  33. #32
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,520
    As youl see by jardos signature, ko3s cars are putting out some immense torque figures recently, proper impressive. So those figures by the OP, just not good at all im afraid. But for obvious reasons.
    Get them sorted, a health check by someone in the know i.e logging, and get back to r-tech for something solid.
  34. #33
    Apr 2013
    Telford
    108
    Thanks for all the views & opinions good or bad the are welcomed I hope that all the crap I have removed today had made a positive impact , now it's just a case of getting it checked out regarding the turbo & n75 & actuator it's my first petrol turbo so it's all new I've had high power diesels & an m3 so I'm reluctant to mess until I know the score , it can't be that difficult but it's nice for someone clued up to show you what the crack is .
    Regards Stuart
  1. Fed up of not seeing the full ETKA screen?
    By Ram in forum General Chat
    Last Post: 31st March 2003, 12:05
  2. Going up.... or not.....
    By Hopsta in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th February 2003, 16:40
  3. S3 Brake Upgrades - not Porsche/Brembo
    By AL_B in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th January 2003, 17:05
  4. To chip or not to chip?
    By Khufu in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th January 2003, 13:40
  5. heated mirrors not working.
    By moschino in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th January 2003, 17:14
