EM TuningJMB Retrofits
    Jun 2012
    Essex
    213
    Poly top mount question
    Hey all,
    I bought a set of poly top mounts of a chap on edition38 ready for when I fit my coilovers on.
    I started prepping the coilovers, cleaning then up and greasing the threads properly so I don't get any future problems.
    But when fitting the new bearings and top mounts, I tighten the nut that normally secures the two to the shock, but my poly bush pulls away with no force at all, if anything, it falls off, with the bearing in place.
    Now, looking at a spare standard shock and top mount etc I have, the standard top mount doesnt move.
    Am I missing something or just doing something wrong?
    Obviously once the shock is in place and secured up with the top cap and nut, its not going anywhere....or will there be too much movement if its not secured like oem.
    Many thanks
    Ben
    Nov 2012
    Plymouth, Devon
    16
    My new top mounts did this.. and they were OEM ones. Use the OEM flat nuts and it should be fine as the mount is held in place by the weight of the car and the top mount nut.
    Ebony Pearl Black 2002 A3 1.8T Sport: K&N 57i Induction Kit + Heatshield, 710N DV, 6000K HID's, LED's all round, AGU Charge Pipe, Einbach ARB, JOM Coilovers (lol), 17" RSTT Wheels, Fully Polybushed, Creations Motorsport Breather Hoses + Boost Pipes, Creations Motorsport TIP, 3" Decat Downpipe, TDI Centre Sec, Tinted Windows, Black Grille Surround, Yellow Fog Lights, Aeroflat Wipers, Team Heko Wind Deflectors, Engine and model Debadge.
    231bhp and 281ft/lbs of R-Tech power!
    Jun 2012
    Essex
    213
    That's what I wanted to hear, thanks.
    i know the weight of the car would hold it in place, I was more that if there was any side or roll movement. Fed up of knocking bushes now, just want to make sure what I had was right.
    thankyou
  1. Poly top mount bushes for S3 8L
    By Nogmeister in forum DPM Performance
    Last Post: 3rd August 2012, 10:20
  2. what do people think of these (poly) top mounts?
    By future in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th July 2012, 16:00
  3. A few lowering questions,springs coilovers top mounts????
    By daz-20vt in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th March 2012, 10:42
  4. Supersport/Eibach - Poly top mounts..
    By Shy19s in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th June 2009, 14:50
  5. Replacement Rear Top Mounts
    By Phantom_A4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd October 2006, 23:24
