Badger5EM Tuning
Like Tree1Likes
  • 1 Post By The Doctor
Thread: Front outer CV joint boot replacement - how to?
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,195
    Well, one job leads to another...
    Replaced my discs & pads on Saturday, only to discover that my front nearside CV joint boot has split where it is held onto the driveshaft. At least that explains the grease I noticed on the inner surface of my front wheel when I washed the car.
    So, does anyone have a "how to" guide for this? I've checked the stickies & can't see one there.
    I'm planning on replacing my suspension soon anyway, so I may as well do this all at the same time if I can.
    Thanks.
    s33nyboy12 likes this.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    I think Tuffty did one mate, its in his build thread or the stickies..
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,195
    Thanks s3dave. Will have a look through.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,453
    The how to was for an inboard joint but the outer one taps off as there is a compressable clip on the end of the drive shaft to tap the back of the joint to get it over that...
    <tuffty/>
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,195
    Do you have any pics, Paul?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,453
    Not of the outer CV no mate...
    Driveshaft gaiter replacement tutorial
    I will add an outer CV replacement section to this next time I do one...
    <tuffty/>
  1. Replacement cost for Inner CV Joint & Boot/ Axle- 2003 A4 1.9TDI Avant auto
    By larry1 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st October 2011, 15:34
  2. Outer CV joint boot clamp
    By voteforpedro in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th November 2008, 19:48
  3. Outer CV joint boot clamp
    Last Post: 24th November 2008, 17:28
  4. Outer CV joint boot clamp
    Last Post: 24th November 2008, 16:20
  5. whats a drive shaft boot? and how much to replace
    By imported_Yaseen in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th October 2004, 10:23
